Question about GE WSXH208A Front Load Washer
Not spining and water not draining off
I have washed my load. but it doesnt seem to spin off the excess water then i realised the water is not draining. After i unload my soaking wash, i switch it off. and restart my machine, it will just continue to wash, and water from the previous wash not draining off... help...
  • 1 more comment
  • Anonymous Dec 01, 2008
    how would i check the filter
  • Anonymous Dec 08, 2008
    same problem
  • myersfam Dec 20, 2008
    I am having the same problem. Wish I would have purchased the extended warranty. It will not spin the water off. Then does not seem to know what to do so it just keeps filling up with more water. Even on the spin cycle. My clothes used to come out soaking wet. Now they are coming out covered with soap. Any ideas?
I had the exact same problem and discovered the filter was totally clogged with junk. You need to take off the front panel and remove the filter to clean it out. You will find a mess of items...rocks, coins, hair clips...you name it! Once I cleaned that filter, the water drained just fine and everything was back to normal. Now I just make sure to clean the filter once a month.
Posted on Sep 29, 2008
    President:
  • 1,462 Answers
Check filter and check for foreign object stuck in pump impellor
Posted on Sep 25, 2008
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The spin cycle is not realising the waste water out of the machine
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 27, 2010 | LG WM-2277HW Front Load Washer
Water not spining out kenmore 11020402990
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 30, 2010 | Kenmore Washing Machines
Access the water pump and look for plugged drain hoses or a plugged filter as well as a slipping impeller on the pump shaft--or even a dead pump motor. Spin usually will not occur if there is a high water level in the machine. Try draining the tub into a bucket, then see if it will go into spin mode. Hope this helps!
Jun 27, 2010 | LG WM2277H Front Load Washer
The spine cycle seem slow need to run more then once
check the tub to pump and pump to drain for blockages of debris,the pump should drain the bulk of the water,then it should spin out the rest unless the belt is that glazed,get to the spin cycle and pull out the washer drain hose out of the house drain stand pipe and see how much force water is while being pumped out while just pumping and not spinning,there should be the water stream the size of the inside of the drain hose and good velocity of water flow to the drain
Mar 13, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Whirlpool will not spin out water
With it spinining fully it may be as simple as a sock or undergarment in the pump, if it is not spining fully the motor coupler is probably in need of replacement
Feb 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine doesnt seem to be draining or spining properly
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 18, 2008 | Hoover H120M Front Load Washer / Dryer
Kenmore 22422 not draining or spining
If it is same as in photo (Frigidaire built) your drain pump is probably blocked/jammed. You have small children?? Kids socks seem to find their way to the pump often.....
Dec 26, 2007 | Kenmore 43142 Front Load Washer
GE WSXH208A Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
