I have a 62 inch Panasonic Plasma that I inherited from a friend (it was apparently going to cost $800 to repair). It worked perfectly for a week, but since then it has continually switched itself off (leaving the little standby light flashing). Occassionally you can get it to go again by switching it on & off continuously, but this is becoming harder & harder
  • twatsonfranc Sep 25, 2008
    Thank you. I have pretty much tried most of these things, but not the sleep mode (I dont have a manual, so I am unsure how to do that at this stage)
    Regards
    Tracey
    Master:
  • 763 Answers
Sir, try to take the plug off for a couple of minutes to refresh the tv. if still the problem persist then send it to repair service to replace some spare parts and fix your tv. if you try it by yourself you should be careful because it may fatal to you. i had experience that someone was trying to fix his tv and then he shock without knowing what was the cause. its not that affect him but it was an accident. i hope that helps sir!
CHARCOIS
Posted on Sep 25, 2008
    Sergeant:
  • 208 Answers
The problem is the three capacitors.
After you have changed them ,your TV will work nice again.
You will find them easily, if you unscrew the back cover on the plasma TV.
Sorry to tell you, that this is the common problem with these sets.
It is a bad capacitor in the main power supply..
There are really about three of them that go bad from time to time.
You should find an authorized repair facility to fix it.
Dont give your plasma tv for repair to an unauthorized centre.
Good luck.
Hope this will fix your problem.
Thank you for using Fixya.
Bye.
Let me know your comments too.
Take care.
  • 1,031 Answers
It sounds like a power supply problem, not anything you have done.This day and age the new electronics are only built for min running requirement, as in the working capacity of the power supply.
It has a standby mode thats why most things have a led to show you if its on or off. so you can have instant picture, if you have turned this type of teleivision off at the wall it would take a few minutes to get a lets say a stable picture.
But this means the the powersupply is only in sleep mode only and uses bare min, to run and when you push the power on button you have life and then your picture.
Try this if and when it comes on and stays on, then it goes off on you, turn it off from at the wall and leave it for 5-10 min and try again, if it comes alive its a heat problem in the supply and maybe a dry joint which needs to be looked at.
If it does not try turning off and on at the set not at the remote, it could be the remote section is not working properly and have the same sort of fault. If you think it could be in the set up, try your sleep mode set up, it could be turned on, so check if the TV goes off at the same time say 5 min's everytime??
If it's the first fault you will have to get it back if its still under warranty very quickly, these are inherent problems, c.
if its the type where you have a power lead that plugs into the set and the wall Check that too, hope this helps
I have a Samsung plasma pn51e550d1f the screen has badly cracked, what is the cost of repair. ,eager to know please anyone? Thanks
Here is an example cost for a Panasonic 50 inch plasma.
$ 2915.00 Plasma screen only - does not include labor to install.
$ 248.00 Maximum shipping cost to deliver it to your home.
$ 3163.00 Total cost - Does not include labor to install.
Probably cheaper to buy a brand new TV.
Aug 17, 2015 | Samsung Televison & Video
I have a 46 inch Panasonic plasma a.HDTV I shipped it on a airplane got home the inside glass was cracked only got 2 weeks of use before i put it in storage every TV repair man tells me its gonna cost more...
If your talking about the front plate go to E-BAY, If all else works and put this in >
Samsung LN26A450 LN26A450C1DXZA /front plate glass
I seen a couple there for $35.00 and installation at local TV repair shop will be cheap less then $100.00 but most wont cover warranty on glass only workmanship. good luck!
Apr 29, 2013 | Televison & Video
Panasonic plasma red light blink 10 times
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS.
These are the faulty boards and sections to be checked. Just visit the site named 'Electro-help'. Blinking codes and repair work with Panasonic plasma TVs are described in detail. Check this link, and select the site. Pull up older posts there.
Jul 21, 2012 | Televison & Video
I have samsung plasma tv 42" ps42c7s,have sound but dark ,no picture
Hi friend,,,
welcome to fixya
Commonly for Plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
We have a panasonic 42 inch plasma, less than 3 weeks old. When connected to our play station or dvd player, there is a white line at the top left of screen, only half way accross then stops. Tried...
Try changing the video output mode of the playstation and dvd player from CVBS (often called composite or video) to RGB. this should sort the problem.
Oct 06, 2009 | Panasonic Televison & Video
I have a panasonic 58 inch plasma that is a little over one year old. About 2" x 8" area on the top right does not display blue color any more. What is the problem? A expensive fix?
probable bad panel. take it to aPanasonic authorized servicer. Also contact Panasonic maybe they will help you out with the cost of the repair. Since the panel is not cost effective to replace.
Jun 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
