Question about Microwave Ovens
My KEN GT/AL17 is displaying a "g" icon under the time display and will not function. Any ideas?
  • William Miller
    William Miller May 11, 2010
    So that's a lower-case letter 'g' it's showing?
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
As requested, the Microwave was unplugged overnight but the hard reset did not work. The lower-case 'g' is still showing
Posted on Sep 26, 2008
The display/control panel on my kitchenaid oven model KESC308LSSO is functional but does not light up. What part would I need to fix this? + looking for video of repair
I assume the display is hard to see but otherwise the unit function correctly? I'm going to gear my answer to this issue. If everything on unit functions but just can't see clock and temp. settings, you have a bad display. That's gonna be part #2. I'm not how to upload video but go to youtube and type in Kitchenaid slide in electric control replacement. The top video should give you a good idea on how to change display board out. Good Luck
Sep 18, 2017 | KitchenAid Microwave Ovens
Samsung Microwave Oven Model smh918713 beeping
You may need to replace the keypad. I found there was moisture causing the problem when we boiled water on the right side of our stove which is under the keypad. I let the microwave dry out for several days and now only use the left side of stove when we boil water and have not had the problem.
Oct 19, 2012 | Samsung Microwave Ovens
We lost power several times last night during hurricane Irene. The power has been on for several hours now and I noticed the freezer LED display is reading "88" and the fridge display is...
If you don't want to roll the unit out, then turn the circuit breaker off in the panel. The quick disconnect does not reset the electronics for the compressor. Try that and see what happens.
Aug 28, 2011 | Microwave Ovens
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My kenwood microwave KEN GT/AL17 wont cook anything. The light comes on and it turns but theres no heat?
This is most likely the high voltage fuse between the transformer and the magnetron. An easy and cheap fix.
Oct 22, 2009 | Microwave Ovens
We are house sitting for friends. They have a Miele Classic, wall mounted combi oven. It has a single dial at the top left of the silver facia. To activate the microwave, I turned the dial one click...
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Please reply back with your brand and full model number.
May 11, 2008 | Microwave Ovens
Microwave Ovens Logo
201 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
