Question about Sony PlayStation Portable (PSP) Console
Cable Hi Guys. Need help, I bought a PSP cable to be plugged into my LCD TV. I used the Video, and 5 other output for the sound. My problem is that there is no sound output on the TV and when I play games there is some noise lines in the LCD. This noise lines does not appear in the PSP menu. My video setting is already set to Progressive. Any inputs will be highly appreciated.
Your gay
Posted on Sep 25, 2008
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I have plugged my PSP into the Game Port using a composite cable. I receive sound, however there is no picture on the AV2.
It is 1 of three things. The video output on the psp is bad the input on the alpine is bad or the cable itself is bad. Try plugging the psp into your tv at home. That will tell you if it is the unit or cable. if it works in your house its your alpine video unit
Nov 17, 2010 | Alpine PKG-RSE2 Car DVD Player
How do I play my games on tv using av cable?
The PSP system (model PSP-2001 and PSP-3001) includes a video-out port which allows users to connect and play the PSP system on an external display or television with AV inputs. It is important to note -- you can
Component AV Cables (model SCPH-98550)
The Component AV Cables connect to the Video Out Port on the bottom of the PSP-2001 or PSP-3001 systems and allow you to output video and audio signal to a television display. The AV Cables support photos, videos (including UMD movies), music, and games. Please note for games to output onto an external display, the display must support progressive scan.
Composite AV Cables (model SCPH-98548)
The AV Cables connect to the Video Out Port on the bottom of the PSP-2001 or PSP-3001 systems and allow you to output video and audio signal toa television display. The AV Cables support photos, videos (includingUMD movies), and music. However, output of games are only supported by PSP-3001.
Sep 28, 2009 | Sony PlayStation Portable (PSP) Slim...
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Feb 10, 2009 | Sony VAIO A250 Notebook
Sony psp slim component cable trouble
Okay the cables you bought they have five plugs. I assuming your tv doesn't have component input only RCA connections (RED, WHITE, YELLOW). SO in that case you bought the wrong jacks. You may want to keep them anyway if you upgrade your tv. Because these "component" cables is the only way you can play video games on the big screen and also has to be hd, but it also will be able to play music, view pics, and watch videos. But that's a different subject.
You need to buy RCA cables for your slim. Keep in mind though you will only be able to watch movies, pics, and music. You won't be able to play video games. Once you have those it's not hard to connect. All you do is from the XMB menu go to display settings click on "switch video output" and it should connect from there. Any more problems please feel free to ask.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Console
Horizontal lines on TV when PSP connected
the cable is contaminated, try using another cable.
now i believe there are two red cables on the component cable two jacks for audio and three for video
check those two red jacks and see if they aren't mixed.
Jun 08, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
