Question about Kenwood Heating & Cooling
I have a Kenwood oil filled heater which is less than three years old. It is now making a high pitched clicking sound. The model number is 2307K. Type is K230715. Serial # 43712 JN
    Genius:
  • 1,011 Answers
Dear,
I would recommend this radiator if you have a smaller place - the living room/dining room is probably 500sf and the radiator works well
regards,
dont rate it untill it gets benificial to u
Posted on Oct 06, 2008
    President:
  • 2,712 Answers
Could be a problem with the transformer or thermistor solenoid. I would recommend getting the heater serviced, as thorough testing is required to diagnose the actual cause.
Hope that helps!
  • 4,472 Answers
It is likely in need of service. They don't have any user serviceable parts your recommended in the manual to locate the nearest service center. I am sure they can give you an estimate of the repair cost.
Here is the toll free number 18003223848
If you still need any assistance let me know. Also if you could please take a moment to accept and rate my solution accordingly I would greatly appreciate it.
Thanks,
Lee
Posted on Sep 25, 2008
I need instrution manual for kenwood model number ew7507ek
Do you mean the Kenwood EW7507EK electric oil-filled heater? ManualsLib has this manual here: https://www.manualslib.com/manual/86348/Kenwood-Ew7507ek.html#manual .
I hope this helps.
Jan 05, 2017 | Kenwood Car Audio & Video
It drains very slowly and it makes a high pitch sound when it does spin...sometimes you hear something tapping or slapping, likesomething is stuck.
To me it sounds like you have something stuck in your pump. I would check that first. I had the high pitched sound during the spin cycle on my machine and it turned out to be the drum bearings. That part used to be covered by a 10 year warranty but not anymore. My machine was less than ten years old and it cost me around 300.00 to fix it. I have paid for my machine 3 times over in repairs. My next washer will NOT be HE and probably an old school Speed Queen
Apr 08, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Kenwood oil filled heater timer starting making a ticking noise. Is there a way to fix it?
Most of these model are not repair able but seems like thermostat problem
Feb 03, 2015 | Kenwood Heating & Cooling
Constant high pitched noise emitting from furnace
This is probably a dry bearing in the vent motor. Those motors run at high RPM's and can make a deafening high pitched squeal if they become dry and need oiling.
Some of the motors have oil cups on them for dripping oil into and others;s are much more difficult as you need to guess where the bearing is and try to drip oil down into them or run the oil to them.
Any light weight small motor oil ike a sewr machine oil will work.
Many hardwares have small oil bottles with extending spouts made just for oiling motors for just a couple of bucks...
The other thing that can cause this is if the blower wheel is coming loose and has moved to the side and is hitting the side of the blower housing. Take the bottom cover off and check for play or movement side to side in the blower wheel. Spinning it with the power off by hand may give you a clue as you will hear it scraping the side of the housing.
Heatman101
Dec 29, 2009 | Goodman GMS90703BXA Heater
I have a tankless Rheem water heater which has begun making noise when the temperature is turned up high, say 135 or 140. It's not a consistent noise. Sometimes it's a somewhat high pitched whine, much...
This sounds like a problem with impurity buildup on the coils. About once a year, More often in high mineral content water, you should clean your heater user a a cleaner that removes lime and mineral deposits. This is usuall called a descaler cleaner.
Hope this helps
Nov 23, 2009 | Water Heaters
Need Instruction Manual, Kenwood Electronic Heater #EW6708K
I have an original Kenwood instruction Manual for the Model
EW6708EK oil filled electronic heater (eng. and spanish)
Nov 21, 2008 | Heating & Cooling
Pelonis HO-0128 makes strange noise
Nothing wrong with it. This is a normal sound made as the oil heats. As the heater heats up, the sounds should subside.
Nov 19, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
TV won't turn on, makes high-pitched clicking noise
Its a real good chance that the HOT (horizontal output tranistor) transistor is shorted if so the flyback trasformer may be bad also. the transformer will make a tick tick sound if it is trying to start.
Mar 30, 2007 | Philips Magnavox MT1905B 19" TV
Heating & Cooling Logo
203 people viewed this question
Top Kenwood Heating & Cooling Experts
john h
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
