Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
My portable danby is stuck on the Drain cycle
I love my danby portable dishwasher but we have had bad luck from the start. When it arrived on christmas 2008, one of the casters was smashed and it was lopsided. We called the business where we purchased it and they ordered a new one, 5 months later, they called to say it was in and ready to exchange however, the front door of the new one had been smashed. So they came and took the front door of the old one with the broken caster, and put it on the new one. Well, we have only had this one for about 3-4 months, and today it stopped working properly. It seems to be stuck in the drain mode. NO matter where we put the settings, it just wants to drain, not allow water in at all. I am so bummed. The one we had with the broken caster worked wonderfully for all that time, we just had to prop it up on wood. Any ideas on how to get it unstuck from the drain cycle? Thanks! Tiffany
  • bradnkysmom Sep 25, 2008
    I did what you suggested, and there was about a small dixie cup full of water in the bottom. I scooped it out and it ran perfect again! I hope it isnt a leak, I will keep an eye on it. Thanks so much for your help!
    Tiffany
Not sure what is meant "bottom front panel" but I have a similar problem. Looked for standing water, removed it, machine seems to work. Mmmmm.... now looking for why this is happening. If it is a "leak" any insite as to what is leaking?
Thanks for your solution, very helpful.
Posted on Jul 24, 2012
  • Peter Malacarne Dec 07, 2013
    Update to my previous post.
    I had water leaking past a seal at the bottom of the drain pan which tripped a cut-off switch for the pump. Fixed the seal and now the dishwasher works like new, and has not leaked in quite a while.
    President:
  • 1,462 Answers
Take bottom front panel off to expose bottom tray and you will probably find it full of water. disconnect from electricity and mop water out and machine should work. if fault reoccurs then you have a leak
Posted on Sep 25, 2008
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
Danby portable dishwasher ddw1899wp starts taking in water and then stops working with pre-rinse light blinking. Please help me on this issue. Any answer would be much appreciated.
If the water level sensor does not electrically shut off when the level needed is reached, the pre-rinse cycle will error out thinking that the level has not been reached. That sensor is a float device and probably needs to be replaced...
Dec 28, 2012 | Danby DDW1899WP Portable Dishwasher
Drain pump wont stop
Hello there and thank you for choosing fixya
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged. or may
be bad and needs to be replaced.
Also if the cycle timer is going out this may cause the drain to continue so i would havethat checked out as well ok?
Hope this helps
Best regards Mike
Aug 04, 2011 | Danby DDW497W Portable Dishwasher
I have a problem where my dishwasher starts its cycle, filling with water, then as it starts it immediately drains as the spray arms are moving. Since the water is draining the dishwasher then pauses to...
It sounds like your motor is stuck in the reverse position. It could also be in your timer. I would suggest calling a qualified technician for the one. Just because the parts are pricey and depending on how much a new dishwasher cost. Atleast get a diagnosis so you can know if its worth fixing or buying a new one. If you have anymore questions please feel free to comment me back.
Jun 05, 2011 | Danby DDW496W Free-Standing Dishwasher
Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Dec 10, 2009 | Danby DDW1805W Designer Series...
Danby portable dishwasher filter stuck
If it says just pull up then you do just that, it is likely rusted on.
Jul 18, 2017 | Danby 22 in. DDW399 Free-standing...
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
437 people viewed this question
Top Danby Dishwashers Experts
Oloyede Monsuru
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
