Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Linksys router befsr41 model
My router was working before ut today it seems not working,i think some changed the configuration. teach me how to set up my router again
  • che963852 Sep 25, 2008
    i dont know how to set it again, i know its plug and play you can teach me how
    i forgot to set up again you can instruct me how? please
    Sergeant:
    Champion:
  • 435 Answers
Since you do not know what has been changed. I would suggest you to reset everything.
I am not sure about your particular model.
But generally, Linksys routers have a small hole called "reset". It should be at the back of your router.
Use a pin, press the reset for few seconds (~30).
Now, everthing is reset.
You the setup CD which came with your router and set it up again from fresh.
hope it works :)
Posted on Sep 25, 2008
Cant get configuration to complete on befsr41 router
Press the reset button on the router for at least 30 seconds. release it. Unplug the power to the router . wait for 10 seconds and plug it back in. Wait for 1 minute and try to set up your router.
If you are having trouble setting up your router with the CD, then you can set up your router without CD also. You can do it manually.
First make sure that your computer is online directly through the modem without the router.
If that is working then you can connect the computer and the modem to the router. Open the set up page of the router and change the settings of the router according to the settings of the Internet service provider
Click here for more information about router set up
Feb 16, 2010 | Linksys EtherFast Cable/DSL Router
Need proper setup for linksys befsr41 to xbox
If the router is already set up, all you should have to do is run cable from router to xbox. Xbox should be set to automatically detect settings.
Nov 14, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Setting up and configuring networks
The main problem on your setup is your router. This BEFSR41 doesn't have wi-fi or wireless capability. You can only go online on your laptop if you connect it hardwired to the router just like your desktop. You must purchase a wireless router if you want your laptop to work wirelessly
May 09, 2009 | Linksys BEFSR41 Cable/DSL Router with 4...
Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Apr 14, 2009 | Linksys EtherFast Cable/DSL Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Setup and confifuration of my linksys befsr41 ver 2 router
Since you did not include your exact model number and type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Dec 17, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Old man with play station 3 problem freezeing after hitting start
Well, actually, the one you have, linksys is the least problematic. The particular model you have also seems to work. I've seen many threads on various forums( while researching an answer for your issue), where Belkin routers were the most troublesome.
Simply ignore the warning and try the game and see if it works or not. If it works, great, if not, then well, nothing much has changed :)
Also, try the ip configuration without the router, with a direct connection, and let me know how it goes..
IrishDruid
Apr 30, 2008 | Computers & Internet
Linksys router limits speed to 5 meg.
Try to access the router's setup page and change the MTU settings. The default address for the Befsr41 is 192.168.1.1. Here are instructions:
1) Use a computer wired to the router.
2) Launch a browser and type in 192.168.1.1, leave the username blank and the password is admin or the password you have set when you first configured the router.
3) Click on the Advanced tab then click on the Filters tab. On the bottom part you have MTU.
4) Enable that option and set MTU to 1500, 1400, 1300 (for cable ISP connection) and 1492 (for DSL connection) and check if it will work.
4) If that does not work, you can try upgrading the firmware of your router.
Apr 29, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Idle
befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Apr 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I don't no how to hook up my Adsl Gateway
See if maybe this will help. You didn't say what type of router(wired or wireless). Yhis should give you some idea. Hope this helps. Thanks
LinkSys Router Setup Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Attach the antennas to the router (if your LinkSys router support wireless)d
  2. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  3. Plug another Ethernet cable into one of the available ports
  4. Plug the other end of that same cable into an Ethernet port on your PC
LinkSys Router Configuration LinkSys routers now ship with a Setup Wizard which is intended to simplfy basic configuration tasks.
We do not recommend the LinkSys Setup Wizard for two reasons:
  1. The Setup Wizard is not significantly easier that the regular configuration menus
  2. If you use the Setup Wizard, you will end up learning two interfaces for your LikSys router instead of just one
Instead, we recommend simply starting your web browser and jumping into the configuration.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password.
Logging in to a LinkSys Router
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
From here the configuration options that you choose are largely up to your own personal preference.
If this is a wireless router, we recommend that you consider setting an SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
Feb 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
