Question about HTC TyTN Smartphone
My telephone dials the number but I cannot either hear the dial tone or hear a person.
I have used the 'phone this morning and all was fine.
I dialled this afternoon and the remote number rings but I hear no dial tone and no response when the remove called person answers it.
Yours sincerely,
Douglass Potts
  • 2,071 Answers
You will have to do a master or "hard" reset which will reset your phone to factory state. This can be done via Tapping Start > Settings > System tab, then tap Clear Storage and input "1234". Conversely you can also hard reset your phone by holding both your softkeys (the physical keys that map to left and right menu options) and using your stylus to hit the reset button while holding those two softkeys.
Warning: when "hard reset" executed ,it will delete all files and back to factory setting...You better save your important files. Hope it may help you; Regards, VOTIT
Posted on Sep 25, 2008
Everything is working fine on my lexmark all-in-one except for the fax. It is dialing the number and says that it is connecting but will not connect. Have cut it off for a period of time then cut it back...
It could be the fax line in the wall. Try to insert a telephone straight to the wall and listen for a dial tone. If you hear no dial tone, please contact your phone company and have them check the line. If you hear a dial tone, re-plug the printer into the wall using a different known working telephone cable. Try to fax again.
Aug 26, 2011 | Lexmark X4250 All-In-One InkJet Printer
What is principle behind pulse dialling mode & tone dialling mode in technical terms
Pulse dialing is a holdover from Rotary phones, which when the rotor is turned and let go, counts out the number you entered in clicks on the telephone line. Pulse, or DTMF (Dual-tone multi-frequency), uses two overlaid tones (one for row and one for column) to signify a button press.
DTMF frequencies:
http://en.wikipedia.org/wiki/Telephone_keypad
Mar 19, 2011 | Cell Phones
My Gigaset AL28H phone is working properlybut I do not get a dialing tone. When I press the green button the previously dialled number is redialled. Can you advise if I have simply set the phone...
this is either because you have completely reduced the volume at which you hear whoever you are talking to or your speaker is faulty.if you are able to hear whoever you are talking to clearly after the person picks up then there is no problem with your speaker but if not that could be it. secondly, you can try using an earpiece and see if it works(ensure the earpiece is working too) if you can hear the person too,i suggest you go thru the phone for any settings have to do with dialling tone(if it has any) or you contact your network provider.hope this helped?
Oct 21, 2010 | Cell Phones
Can not dial out and people can not hear me when they call in
model no.kx-tg 2303cb not dialling only ring tone we can hear
Aug 06, 2009 | Uniden Cordless Phone
No sound when dialling out
for those of you having this problem, what you need to do (as i so annoyingly discovered) is to 'delete all' in your previously called numbers, then it dials out just fine. lame, but it works. :D
Jun 09, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Modem, Dial Up Connection Problem
here's some help...go to : start menu,all programmes,accessories,communications and to hyper terminal..type in test, and click o.k.,make sure all the settings are o.k., type in your mobile or your second land line number to test if the modem dials that number.if that test works then contact your i.s.p to check on your account.
Sep 03, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
HTC TyTN Smartphone Logo
153 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
