Laptop screen will not light up
My Alienware laptop screen will not light up. If you use a flashlight or bright light you can see parts of the screen but makes for some real eye strain. Why is this, please help me
  • 1 more comment
  • Cam6381 Mar 04, 2009
  • wolf_59 Mar 21, 2009
    dell latitude d630
    screen bipped and went dark as i was working
    can barely make out the lighter sections of the screen
  • Anonymous Apr 15, 2009
    Habit-Forming:
  • 21 Answers
It sounds like the inverter for the backlight has died.
They are about $100, unless you shop eBay. I just found one for my sister's AlienWare D9T for $36 with shipping.
The little rubber buttons around the screen must come off, they are just stuck on with sticky-stuff, but they are tenacious. Underneath there are small philips-head screws, you'll need to get a small set if you haven't already.
Then after the screws are out around the bezel (that's what the plastic around the screen is called) you'll have to carefully pop it off. There are several tabs around the edges, be careful not to break the tabs or the bezel. Be patient.
At the bottom of the screen, there is a narrow board with LEDs and buttons on it, and the large lump is the transformer used in the inverter to create the high-voltage AC required by the backlight tubes. There will be one or two small philips-head screws holding it in.
That is the board you'll need to replace. A big, big caution: on my sister's AlienWare, the connectors on the cables are really horrible. The plastic is crumbling, they are -very- difficult to remove without falling apart. If you break them, it is a -lot- more complex replacing those cables. Once you have to open the main part of a laptop, it starts reminding me of the puzzlebox in "Hellraiser".
I hope this helps, Steve Greenfield
Electronic Engineering Technician student
Electronic Technician 20+ years
CET Computers and Consumer Electronics
IPC-A-610D CIS Specialist
Posted on Feb 06, 2010
  • 97 Answers
Let's Diagnose only...
- Try to connect CRT Monitor if they have a display?
- if not you LCD screen have a problem.
Posted on Sep 25, 2008
How to reduce brightness of dell vostro 1015
not sure if this will help you...
  1. Bright LCD displays under low-light conditions can strain the eyes. ...
  2. Hold the "Fn" key and press the up or down arrows to increase or reduce brightness on most Dell laptops. ...
  3. Right-click the power icon in your Windows 7 system tray and select "Adjust Screen Brightness."
How to Adjust Dell Laptop Screen Brightness ' Chron.com
smallbusiness.chron.com/adjust-dell-laptop-screen-brightness-53143.html...or try this link. How to reduce brightness of dell vostro 1015 Google Search
Oct 21, 2017 | Dell Computers & Internet
Screen is way too bright, unable to change
On your keyboard there is a key labeled "FN" press and hold that while tapping the up or down arrow keys
Aug 23, 2012 | Dell Studio 1537 Laptop
What kinds of a flashlight the brightest?
Check out this WEB site for super bright LED flashlights.
http://www.nextag.com/super-bright-led-flashlight/stores-html
Nov 28, 2011 | Camping, Backpacking & Hiking
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
THE PICTURE ON MY ZENETH PV6067DT TV WILL NOT GET
Make sure there is no light shining on the electric eye it will adjust brightness automatically also check bulb for dust and dirt
Nov 30, 2009 | GPS
Real dark screen on Toshiba A135-s4437
First I would check to make sure that the contrast/brightness buttons on the laptop weren't accidentally changed, making the screen dark. Also, try with and without the battery and power supply. Otherwise, unless it is actually the screen that is defective, it is usually a power converter replacement, which is a small circuit board, usually under the plastic cover directly under the monitor, which supplies power to the monitor. You may want to take it to a shop as they can isolate the issue easier.....
Mar 10, 2009 | Toshiba Satellite A135-S4437...
Screen is on but picture dose not show... cables connected
Solution, replace monitor with a new one.
I have found, at my shop, that getting parts for these things can be pricey and by the time I charge labor as well, could just buy a new one.
Probably a bad internal power supply or the inverter that powers the bulb(s) went out, which is sometimes built in with the power supply itself. If, and I stress IF, the parts are available, be prepared to pay more than its worth.
Pick up a new one, shop around on different brands. Some manufacturers offer 3 year warranties. ;)
Oct 23, 2007 | Scanport 17" LCD Monitor
Computers & Internet Logo
1,073 people viewed this question
David Payne
David Payne
