Question about Honeywell Heating & Cooling
My thermostat display is showing all of the symbols. The whole thing is full, and it's not operating the air conditioning.
Well, I don`t undersatand how it really works, what I have at home produce a sound but I don`t feel air coming through, hot or warm but sound like if it would be working.
Posted on Oct 13, 2008
  • 182 Answers
Change the batteries?If thats not it then change the thermostat
Posted on Sep 25, 2008
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
Tip
Air Conditioners Cooling Tips
  • Whole-house fans help cool your home by pulling cool air through the house and exhausting warm air through the attic.
  • Set your thermostat as high as comfortably possible in the summer. The smaller the difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be.
  • Avoid setting your thermostat at a colder setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing your power use.
  • Avoid placing lamps or TV sets near your air-conditioning thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
  • Plant trees or shrubs to shade air conditioning units but not to block the airflow. Place your room air conditioner on the north side of the house. A unit operating in the shade uses as much as 10% less electricity than the same one operating in the sun.
  • on Sep 21, 2010 | Heating & Cooling
    Honeywell Thermostat for gas fireplace not working
    sir there is some probalm in LED change it for use
    Jan 25, 2014 | Honeywell Heating & Cooling
    The unit keeps flashing
    By unit, do you mean the thermostat? And if so, do you mean the whole face is flashing, or just a heat or cool symbol? And if your talking about the heating/cooling unit, are you talking about a flash on the board?
    A thermostat face that is flashing is usually batteries.
    A symbol that is flashing on a thermostat indicates a call and is in a delay. There will be a 5 minute delay on calls if the call has been short cycled, powered off and on, etc.
    If the symbol continues to flash for an extended amount of time, then the problem is in the furnace, air handler, etc.
    If the system is working, but flashing, then it could be the programming of the thermostat.
    Dec 02, 2013 | Honeywell Heating & Cooling
    Changed the thermostat car still getting hot pouring out of the overflow only place we can find leaking what causes this
    the radiator is partially blocked, and heat transfer from water to air cannot be acheived, the radiator, if in good condition can be taken apart and the tubed cleaned, if the radiator is showing signs of fin deteriation, the whole thing must be replaced.
    Dec 01, 2012 | Cars & Trucks
    What symbol is for air conditioning?
    Here is the operating manual
    www.fujitsugeneral.com/.../OwnersManuals/OPManCeilingSuspended.pdf
    On Page EN 7 it has the operating instructions for the hand held remote unit. When the word "cool" appears in the display, depending on the temperature that the room is and what the remote is set for, the unit will function in the air conditioning mode.
    Nov 28, 2010 | Fujitsu 36CS Air Conditioner
    I need download the user guide of Mitsubishi rkn502a remote control
    Search Results
      [PDF]user's manual mitsubishi daiya room air ... - 3D Air Sales Ltd
      www.3dair.co.uk/DOWNLOADS...manuals/O&M%20RAC%20-%20SR...
      MITSUBISHI DAIYA ... performance, read and follow this User's Manual carefully before using your air condi- ... Operation and indication section for remote control . ....Symbols which appear frequently in the text have the following meaning:.
      Air Conditioning User Manuals - Mitsubishi Electric Australia
      www.mitsubishielectric.com.au/Air_Conditioning_Use...
      Mitsubishi ElectricUser Manuals/instruction booklets (including remote control instructions) forMitsubishi Electric Air Conditioners. ... Air Conditioning Downloads · Residential Air ...Need to know how to operate a Mitsubishi Electric air conditioning system?
      Remote Control Symbols - Mitsubishi Electric
    Aug 20, 2010 | Heating & Cooling
    Flame symbol showing on theremostat
    It's not your thermostat. Go to where your heating system is and give us a make and model number so we may help you.
    Feb 11, 2010 | Honeywell Programmable Thermostat Heater
    Heating & Cooling Logo
    90 people viewed this question
    Top Honeywell Heating & Cooling Experts
    Bill Long
    Paul Carew
    vance jones
    Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
