Question about Prima C2012 TV
Screen turns bright red
I'll be watching tv for an hour or little more than red screen. No type of warning. Turn it off for a while and its fine --- for a little while.
  • 188 Answers
If your TV works for an hour or so then it is probably not a connection problem. It sounds like a component is heating up or there is a problem with your picture tube. Make sure the TV has enough ventilation around it but it maybe time to think about getting a new one.
Posted on Sep 25, 2008
Cooling fan, tv wont turn on
Inspect customer replaceable lamp first--lamp has a 2,000 hour life and may be bad---you getting any brightness on screen etc?
Apr 15, 2012 | Televison & Video
Screen loses brightness at irregular intervals, then eventually returns to normal brightness.
Shut off the whole TV including the cable and the wires. Wait for about an hour and then turn it back on!
Dec 10, 2011 | LG 32LG30 32 in. LCD HDTV
Why does my tv turn on for a little bit but cant see the screen and a red light flashes
Tv red LED lights indication front of the bazel screen flashing are most common problems.When was the last time the projection lamp was replaced in this tv?The lamp in the tv now,is it in the the tv about 1 1/2 or 2 years and tv on watches about 4 or 5 hours a day in used?The projection lamp life are over.Require a new projection lamp.
Aug 03, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
Won't work just bright red screen
check the G2 voltage on the tube base board it should be +- 520 V >if this voltage goes high it can cause scan lines and bright colours/loss of RG or B
Apr 13, 2010 | Disney DTD1363-CAR 13" TV/DVD
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Sony KP75HW40 unstable red. (not the usual problem)
I would suggest either the Focus block or the RED CRT drive board either one of those items could cause the symptom. A defective CRT could also, but a shorted CRT doesnt usually go back to being normal
Mar 16, 2009 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi tv problem
im assumiong you checked the tint in the menu options. if not go check it. other wise it sounds like you have a weak tube, or you do not know how to adjust the screen brightness. this is how i adjust the brightness (you dont need to touch the focus). turn the red up until your whole screen is tinted red, then do the same with the blue and the green. then go through each one and turn down just a little till your pic darkens a little. good luck
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Nov 26, 2007 | Toshiba 53H71 53 in. Rear Projection...
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
Nov 07, 2007 | Sony KP-51WS510 51" Rear Projection...
Prima C2012 TV Logo
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
