Question about Texas Instruments TI-84 Plus Calculator
When I type in (0.02) to the power of 2, it displays E. I want decimals
When I type in (0.02) squared, on TI-84 Plus, I get an answer 4E to the power of -4. On my TI36X, I get an answer of 0.0004. Why can't I get my TI-84 to display the same wasy as TI36? I checked all the Mode settings and they seem to be fine. Please help
  • Texas Instru... Master
  • 8,073 Answers
If number format in MODE is set to Normal, and if the (absolute value of) the number is smaller than 0.001,the calculator displays it in scientific notation( with the E). By the way E( ) stands for x10^( ).
Posted on Sep 06, 2009
If i Type Square root of 148, i get some wierd decimal, i dont want that. I want a radical like 3 radical 12 i think thats the answer, how do i get it to display that insted everytime for when i type in...
The square root of 148 is 2*sqrt(37), the square of 3*sqrt(12) is 108, but that's not the point.
The TI-84 can't produce results like 2*sqrt(37). It can produce results as fractions but not involving roots. Some other machines, like the TI-89 can, but not the 84.
Sorry if that wasn't the answer you were hoping for.
Nov 07, 2013 | Texas Instruments TI-84 Plus Silver...
I'm using a Ti-84 plus and when I try simple division it gives incorrect answers. For example, when I enter 5/2 it answers 3. When I entered 50/100 it answers 1.
You apparently have your calculator set to display no digits to the right of the decimal point. 5/2 is 2.5, which rounds to 3, and 50/100 is 0.5, which rounds to 1.
To change the display setting, press MODE, highlight the desired settings on the first two lines, then press ENTER followed by 2ND QUIT. Try setting "NORMAL" and "FLOAT" and see what results you get now.
Oct 06, 2013 | Texas Instruments TI-84 Plus Calculator
Ti-84plus keypad for ti-nspire w/touchpad while in a+bi mode i enter the the problem (2-5i) / (1-6i). once i press "ENTER" i get a decimal. i want the answer in frac form, but when i press...
Here is screen capture of the calculation, performed on TINspire with TI 84 plus keyboard.To type in the imaginary unit use key sequence [2nd][dot], do not use [ALPHA][X^2] for the letter I.
k24674_90.jpg,
Jun 09, 2011 | Texas Instruments TI-84 Plus Calculator
How do you do you put square roots into its simplest radical form? Because I can do small numbers mentally but when they are bigger I get stuck..
well,
I really don't like to tell this to you but the Ti-84 plus will not display a square root as an answer, it will always return answers in decimal form. The best way for you to simplify roots is by using a factor tree and knowing your squares up to 30. I went through all of that using a ti-83 plus so I completely understand your desire for it to show a root, it just won't. I really wish you the best with this problem, but having read the owners manual for it, I just don't see any other way to do it.
Mar 21, 2011 | Texas Instruments TI-84 Plus Calculator
I when i power -3 to the second i get -9 when it should be just 9
No, is giving you the correct result. When you negate 3-squared, you should get -9. If you want to square negative three, you need to type it in as ( (-) 3 ) ^ 2 or ( (-) 3 ) x^2
There is a difference between (-3)^2 and -(3^2). If you omit the parentheses, the calculator will interpret it as the latter.
If in doubt, use parentheses.
Feb 17, 2011 | Texas Instruments TI-84 Plus Calculator
My Ti-84 plus gives me an answer of "4E-4" when I multiply .02 times itself. How can I get it to show me the decimal answer instead of the E
Unfortunately, you can't. From the manual:
If [...] the answer cannot display in 10 digits (or the absolute value is less than 0.001), the TI-84Plus expresses the answer in scientifc notation.
Oct 05, 2010 | Texas Instruments TI-84 Plus Calculator
Please help me to use my TI - 84 so I can get a radical number when working with larger numbers. the steps I must take and having the TI - 84 set to the right function
I am afraid I do not completely understand what you want. This calculator does not have a Computer Algebra System or CAS. So the results of all calculations will be displayed as decimal numbers, and that includes the square and other roots that are irrational numbers (square root of 2, 3, 5 7, etc.)
You cannot manipulate radicals on this calculator, whether for small numbers or large numbers. Sorry.
Sep 09, 2010 | Texas Instruments TI-84 Plus Silver...
How do I on a TI-84 Plus Simplify Fractions
Enter the fraction for example: enter 8/12.
The answer will be .666666
Then click Math (which is located under the Alpha button).
Click the ->Frac button (the first one).
It should come up as Ans->Frac.
Click Enter.
It should now read 2/3 which is 8/12 reduced.
Note: I have a TI-84 Plus Silver Edition, and the TI-84 Plus might not have this function, but that is how I do it on my TI-84 Plus Silver Edition
Nov 08, 2008 | Office Equipment & Supplies
Texas Instruments TI-84 Plus Calculator Logo
515 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
