Question about Dell Axim X50v Pocket PC
Power button flashing green
After I dismiss notification power button wont stop flashing
  • saddess Sep 25, 2008
    It didn`t help and I don`t want to do a hard reset.
  • Dell Master
  • 13,433 Answers
Goto notification settings and change the setting or turn it off. if that doesn't work try a reset. optionally you could hard reset to restore defailts.
Posted on Sep 25, 2008
How do I get the home button to stop flashing green?
Perhaps you should reset the phone, or clear some memory?
Jun 05, 2014 | LG Optimus F6 for MetroPCS CePhone
Red light blinks 5 times and wont power on. Is not the bulb
error code is model specific---some it means lamp door issue and others something else.
Oct 31, 2012 | Sony Televison & Video
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
Wont print error 5100
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off printer by pressing the power button
press the Resume button and press Power button.
Keep holding down Power button and release Resume button
Press Resume button 2 times then release BOTH buttons
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Nov 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Many issues, ie, Everything is flashing!
Hi there
yOU CAN ONLY TRY.
not know if it will work so you go to come back to let us know pleas.
Also if you are using the Refillable ink cartilages stop they always cause major issues
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Wont turn on just flashes.wont turn off just flashes...Is there a reset button??All of a sudden it just stopped and started flashing no warning.
First try to turn off PC by holding power button for more than 5 seconds. Make sure first that your PC is clean inside and CPU is properly connected to motherboard (before you touch inside your PC touch some metal to discharge electrostatic). If it needs cleaning use canned air and paintbrush. Check how memory is connected. Check the Power Supply voltage, if it's ok, first turn PC off,then you can check power button by disconnecting ATX 20 or 24 pin power connector from motherboard and connect paperclip edges to any green to black wires it has to power on your PC. If it's still flashes it's more likely PSU or motherboard issue.
Jan 15, 2010 | HP OfficeMax - CPQ SR1638 NX-B Desktop....
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
8. Your printer should respond as normal..
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Blinking Green Ligh
Yes, this blinking green light is an appointment notification. So if you set up an appointment for September 30th, 2005 at 9:00 AM with a reminder set to 1 day....then on Sept 29th at 9:00AM, the IPAQ will turn itself on and a reminder screen will appear on your IPAQ. After a length of time (the default of which I can't remember now) the Ipaq will turn itself off, but will leave that green light flashing. When you then turn the IPAQ back on, the reminder screen will again appear and you can choose to dismiss the reminder or snooze it.
Sep 07, 2005 | HP iPAQ HX2415 Pocket PC
Dell Axim X50v Pocket PC Logo
91 people viewed this question
Alun Cox
