Question about Brother MFC 240C All-In-One InkJet Printer
Will not print
When i go to print, it will flash "recieving data" for like a second, then it will disapear, and go directly into trying to fax something. Sometimes, it wont attempt to print it at all, and it repeatly tries to fax.
  • cincy_bound1 Oct 19, 2008
    Will not print, says ready but does nothing afterwards, will not even scan. Have tried unplugging it and powering off, but doesn't help
    Champion:
  • 320 Answers
I would first uninstall the software that came with the brother machine and then reinstall the cd and reset up the printer,hope that this helps, if not post to me again and i will serch the service manual. good luck brother tech
Posted on Jan 17, 2009
Cannot print from flash drive
One method, press the SCAN button (LCD will show Save to PC) then insert USB flash drive into the Direct Print Port. Use the left and right arrow button to select USB flash drive, then press OK button.
Second method, is press the FAX button then press the Menu button. Insert the USB flash drive into the Direct Print Port.
If you can access the USB drive using either method then you know the printer recognized the drive successfully.
Nov 05, 2013 | Canon pixma mx310 color ink-jet - fax /...
I received several important faxes that did not print, just blank paper. Then I realized I was out of ink. Anyway to retreve those lost faxes?
Not normally...once the machine "thinks" it has printed the information the actual Data is no longer kept in memory...there may be a record of the fax being recieved but not the actual Data.
Feb 13, 2011 | HP 1040 Plain Paper Inkjet Fax
Check document error when I try to fax a document
You should try a copy to see if it prints OK, when the scanner goes out you sometimes get a black page and your fax machine knows it looks like way too much data.
Jun 15, 2009 | Canon MultiPASS F50 All-In-One InkJet...
1840C Brother fax machine
Do you have ink / toner / paper?
Unplug the power cord for 10 seconds.
Sep 08, 2008 | Brother IntelliFAX 1840C Plain Paper...
Fax recieving faxs
If you only use this line for a fax the least stressful option is a fax to email service and re-direct the incomming calls.
If you use this line for fax and phone do as I suggest above except re-directing the calls but dont forget to tell those who fax you of your new number
Jul 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
I can print but can't copy or recieve faxes
you can try the following steps .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
Thanks
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Brother MFC 240C All-In-One InkJet Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
