Question about Sharp AR-5320 Black and White Copier
Display shows 'E' , what may be the cause?
CMERI , India have a Sharp AR5320 machine, which displays E (blinking E & 7 alternatively), and m/c does not responded with any other switch. what may be the cause? Please reply.
Biplab swarnakar
CMERI, Durgapur
  • Sharp Master
  • 2,794 Answers
There should be two more numbers to that error code. Do you know what they are?
Posted on Sep 26, 2008
ERROR CODEE7-10
E7-10 Shading trouble (Black correction)
The CCD black scan level is abnormal when shading. Improper connection of the CCD unit flat cable CCD unit abnormality MCU PWB abnormality. http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Sharp&model=AR5320
upon on extra research I've found that this problem was once solved by tightening any loose panels and screws...
Thread Sharp ar5320 error code e7
Sep 23, 2015 | Sharp AR-5320 Black and White Copier
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
H2 code
Put on ur machine & go 2 ur display board & press the C button twice then ur display will go off then input figure 1 & 4 that is 14 then press the print button. if this fails then remove ur fuser unit & check d thermistor, clean any dirt b/w d fuser roller & the thermistor, u can test d thermistor by connecting the two terminal 2 ohms meter
Dec 04, 2013 | Sharp AR-5320 Black and White Copier
While starting the xerox machine SHARP AR 5316 , indicator is showing 4 and blinking everytime, unable to take the printout
I'm going to guess that if you watch the display closely, it is alternating between an "H", and a "4". If that is the case, you have an "H4" error code. This is a fuser error and can either be a freak out from the machine, or an indication of something serious. I would recommend resetting the code and seeing if it comes back. To reset the code, turn the machine on and press "#" -> "Interrupt" -> "Clear" -> "Interrupt". Doing this should put you into service mode, where the display will show a blinking double dash (--). Enter 14 and press the green start button, just like you are trying to make 14 copies of something. At this point, the machine should restart itself and hopefully the error code will go away. If the error code does not go away, or recurs on a fairly frequent basis, I would recommend contacting a professional service technician.
Feb 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar5320 has an error code blinking it flashes h 4 what would i do?
On your keypad press in order # * C * .That will put the machine in diagnostics. Then enter 14 like you were making 14 copies. then press 1, then start, that will reset the machine.
Aug 09, 2010 | Sharp AR-5320 Black and White Copier
"P" is blinking in display Sharp AL-1641cs
There is a small white gear that drives the fuser module. It wears out at 30 to 40 thousand pages.
If the sound is a jumping to gringing noise that would be the problem.
That gear jumping will cause the machine to say out of paper,, jam,, give all kinds of problems from things bouncing around.
Aug 02, 2010 | Sharp AL-1641CS Laser Digital Copier
Sharp ar5320 copier
H2 on a Sharp machine is the fusing unit is not heating up. This could be the heating lamp. therimstor, thermal fuse of fuser control.
If you are so inclined, you could test the lamp, and fuse for continuity.
Hope this is of some help.
Ed
May 19, 2009 | Sharp AR-5320 Black and White Copier
Blinking with L and 1 alternately
Hi:
L-1 is caused by the scanner lock being partially or fully engaged. The scanner lock is located under the left front corner of the machine. It should be a round plastic dial. Make sure it is in the unlocked position. If you crouch down and look under the left front corner you should see the dial.
Andrew
Mar 16, 2009 | Sharp AR-5316 Advanced Digital Imager...
Driver update problem.
first unistall all sharp ar5320 drivers from computer , restart computer and unplug printer cable then install printer driver( AR5320) after finiishing all then plug printer cable and power on 5320 machine
Nov 03, 2008 | Sharp AR-5320 Black and White Copier
Sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Sep 16, 2008 | Office Equipment & Supplies
Sharp AR-5320 Black and White Copier Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
