We have two drawers (separate from each other) and one works well, but the other does not drain all the water out properly after the cycle. I have cleaned everything that I can think of to clean but nothing has worked.
We had this problem. wqe had a small bone blocking off the drain tube a bit. Take all the parts on the inside of the draw out ie mesh rack, remove the strainer, steel plate and remove the spinner. Now get a small pipecleaner or brush and poke it up where the strainer inlet is. You will probably see it pock through the centre where the spinner is. Give it a go.
I've cleaned everything and my FP still keeps water after the cycle has run. The only way I've found to drain it is to start a cycle (any), carefully watch the kitchen drain where the water drains to and listen for draining water, then cancel the cycle (not pause). Sometimes I have to do this 3 or 4 times to get the water completely drained out.
