Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
No av-input picture with sound
Over several months, my 60" has been talking to me. I havent a clue what it is trying to tell me. Every av connection will not work, except the HD input #4 which provides me with directv programs. Plus, the sound periodically chirps like a bird with low volume, then rises back to previous volume setting.
  • Philips Master
  • 3,459 Answers
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Posted on Jan 26, 2009
I have a sharp lc30hv6u LCD flat screen TV I'm trying to only watch TV what cable do I need and what is the difference between inputs 1 2 & 3 thank you
You need to re-thnk how this tv works. The AVS system box that came with the TV which is at the bottom of your picture controls the inputs. So a TV antenna goes into the ANT-A in the top left corner of the back of the AVS system box. The AVS cable has to connect the TV to the AVS system. So the inputs 1 2 3 have to be all connected . I assume to watch TV you need to somehow tell the AVS system to switch the AVS to TV.
I have seen a similar system with an after market sound and video processor that switches the audio and video to the tv from many different sources.
Mar 13, 2017 | Sharp Televison & Video
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
First, set [SWITCH TO ANALOG I/O] to [OUTPUT]
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
My wife thought it was hooked to a cable box for high number channels and pushed 707 on the remote TV sig went out. TV powers up but no menu no signal just a power light and the background is on but no...
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
Nov 25, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
TV has no picture, but sound works fine
Are you using the AV input for the XBox or other cable? If you use AV, then use the same input that the Xbox does not show picture, plug in a DVD and see if it works. If it does not have a picture, so 100% your TV has problem.
Aug 11, 2009 | Sony Televison & Video
Audio but no picture
sound is one circuit ... picture is over 3 thousand. I havent a clue either.
try turning it off and on fast... if see a flash or white flash you have high voltage at least as high voltage collaspes. check your inputs on remote you might be on av 2 or something.
Sep 13, 2008 | Mitsubishi WT-46809 46" Rear Projection...
LG video/vcr. I can hear the movie sound track playing but there is no picture. The video screen says"Pscan" - I can see no button on the remote or video
your AV leads are probably connected wrong,you need send signal from.......to on the yellow lead
ie from dvd player TO telle,using AV inputs on telle,then swith telle to AV 0r 2
Jul 15, 2008 | Televison & Video
No picyure
you havent connected the av leads properly,red and white are for sound and should go from audio out on tv to audio in on sound system,
yellow lead is for picture (aka video) goes video out on dvd player.to video in on TV
basically you need sent video signal from......to
normally have to use AV inputs,so u need turn telle to AV1 or 2
Jul 07, 2008 | Durabrand STS92 System
Have an AVR-2807 with a Toshiba DVD and Harmony remote. Havent played a DVD for a while and tonight when I try, I get picture and no sound. If I move the input to CD I get sound but I lose picture. ...
Have you changed the connections recently? If so, maybe something got plugged back in differently.
Otherwise check the AVR-2807's System Setup. There is a menu to associate different video inputs to each of the audio inputs. Probably the input with sound doesn't have the right video input associated with it, though I'm not sure you can associate a video input with the CD input... which tells me maybe the connections got changed?
Apr 05, 2008 | Televison & Video
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
No av picture
I have the same problem. Any suggestions
Sep 02, 2006 | Philips 60P8342 60" Rear Projection...
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
