Question about Lite On LVC-9016G DVD Recorder/VCR
Says "hello" then does nothing and says "stop"
When I turn unit on it says "Hello" then is frozen, not accepting any commands from remote or unit. It will then say"Stop". I've unpluged it and plugged in, no help. Please help
  • Anonymous Sep 27, 2008
    Same problem.
    Says hello and nothing else. how do you reset.
Try tv on video 1 or 2 or 3 or AV or hit the set up button tv to get to right place
Posted on Jan 24, 2009
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
Element 40 led will not accept any remote control codes supplied by element technical support also Comcast technical was at my residence for 1hr tried 5 different remotes nothing works?
Hi Larry,
What did the Comcast Tech say in the end? In such cases either the remote senser inside the TV goes bad or the micro processor stops accepting the command. Unfortunately there is nothing you can do about it yourself. Ask the Comcast or someone else who can fix it.
Apr 13, 2015 | Element ELCHW402 40 in. LCD HDTV
Bought used roper washer. worked for first load and now wont work. washes and then the dial satys in same place. Wont empty or spin, nothing.
Hello, Thank You for using FixYa. I will be helping you today. If the unit fills and agitates but wont spin or drain the yourlid switch is bad..Here is a link to order the part and a how to video
http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Roper RAS8445KQ Top Load Washer
I had some wine over my controle.i cleaned it.and now it given a remote dvd 2 at the .i did enter and 1 but it does nothing.i try to reset the system but nothing works.if i put a button ythan he...
Sounds like the unit is in remote command mode 2 (DVD 2) - and you set the remote incorrectly, since you said you did ENTER and 1 on it. You can try to reset the remote to command mode 2 (DVD 2) by pressing (and holding) ENTER and 2 (together) - for 5 - 10 seconds - on the remote while pointing it at the unit, then release. The remote should now match/command the unit correctly and fully (unit must be turned on when doing this and should always be done whenever batteries are replaced in the remote).
This hopefully should work for you.
May 02, 2011 | Panasonic DMR-EH60 DVD Recorder/HDD...
Hello, my remote for my Panasonic DMR-EZ47V DVD Recorder / VCR Combo recently stopped working, and whenever I press a button on the remote, I get a message on the display as "RC1" I'm guessing...
Actually, you are sort of correct, in a sense, RC1 means remote command mode 1 (the default mode of your combo unit). There is one way you can try to fix this:
Remove the batteries from the remote, press any button on it to clear its existing memory buffer, then re-insert them or replace them with new ones. While unit is on (no DVDs or tapes in it), point the remote at it - press and hold 1 and ENTER/OK buttons together for 10 seconds, then release.
This should (in most cases) restore full remote command operation to your combo unit - if when you press a channel button on it, and the unit's front channel changes, the remote is now functioning as it is meant to.
The good news is this will constitute any workshop repairs or costs (except perhaps new batteries for the remote if required).
I hope this helps a bit.
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Hitachi ras-35ca1 unit and the remote control stopped working. I can manually turn the unit on but cannot change any settings. I brought a Digitech universal remote to control the unit but I...
Hello Rachael8104,
I unserstand that you are having a problem with you Hitachi air conditioner split nonduct unit. I have located a web page for you to contact the nearest local dealer to your area. Follow the follow url to the webpage and pick the closet dealer and see if they can not order you a replacement remote for your unit http://www.hitachiaircon.com.au/contact-us.aspx
Thank you for choosing FixYa.com
Justin
Apr 03, 2011 | Heating & Cooling
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Stuck on "Hello"
This product is known for freezing up. You can get it fixed but it will cost more than you paid for the machine. Best advice, throw it away and buy a name brand recorder. The company will stand behind their products instead of dodging their responsibility of making a decent machine and ripping everyone off. I learned the hard way too, and yes, it hurts the pride.
Sep 11, 2006 | iLO DVDR05 DVD Recorder
Lite On LVC-9016G DVD Recorder/VCR Logo
202 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
