Question about Westinghouse Refrigerators
I have a small 2 door fridge a westinghouse 221. The fridge thermostat does not appear to work as the fridge freezes everything and the motor runs continuously
    Scholar:
  • 121 Answers
Possible or it could be the divider between the frig and freezer
Posted on Sep 25, 2008
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Westinghouse virtuoso fridge- my top panel has gone blank - and everything in my fridge is now freezing - is there an easy solution to fix this ??
Sounds like the thermostat has failed to on and the machine just keeps freezing. Before replacing the panel try turning the power off to the fridge at the wall for 2 minuites and then return the power.
Apr 05, 2014 | Refrigerators
Westinghouse 633 litle, 2 door
The latest 2 door Westinghouse 610 litre without ice maker is a 2.5 star rating with energy consumption (kwh/year) quoted as 605. We had an older 633 litre Westinghouse about 20 years ago which was less efficient and I would assume about 2 star rating. With older fridges the door seal and thermostat are more important as they will waste electricity if not working well.
Mar 12, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Feb 14, 2014 | Refrigerators
White Westinghouse ( Model# MRT 18FNEWO
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 24, 2011 | Refrigerators
My amerian fridge freeze the fridge is frezzing everything
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem as you read the above information to get your fridge freezer back again...
Jun 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Feb 12, 2011 | Westinghouse Refrigerators
Hi i have a samsung cooltech fridge freezer and the fridge freezes everything overnight...turned the thermostat down to min but made no difference...best way to fix it ????
I hope that this will helpout in solving the problem.....
Dec 09, 2010 | Samsung Refrigerators
My freezer compartment isn't freezing
check the thermostat and test for power by motor if there are power by the motor and the motor are running there are no gas in the system
May 14, 2009 | Maytag PTB1952GR Top Freezer Refrigerator
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Refrigerators Logo
399 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
