Question about Sceptre X9G-NagaIV 19" LCD Monitor
Monitor takes a long time to wake up
The XP power management is set to turn the monitor off after 20 minutes of inactivity. Everything else is set to stay on. For the past month, after no activity for 3 or more hours, it takes the monitor over a minute to bring up the picture. Does anyone have any suggestion on what could be causing the? I checked the system power supply and it is working properly. Is this a sign that my monitor is starting to fell?
Replace 2 caps 1000uf each 16 volt
I purchased 5 of these babies (new) at the same time and 3 of them had this problem
Posted on Sep 27, 2008
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
We have rolled out Dell Optiplex 790 machines running Win XP and using E2210 monitors. Recently networking applied power managment options to power of the monitors in 20 mins of inactivity. The monitor...
Turn off power saving mode in your monitor. In monitor beside orange light there will be a menu button press it and find for power management ok it turn of power management. The problem will be fix.
Sep 13, 2017 | Dell E2210 22" Widescreen Flat Panel...
Monitor will not wake up with keyboard or mouse after going to sleep from inactivity
turn off the computer's power management, there is an issue with the video card/OS and your power management. Set the power management scheme for the monitor to always on, or disable power management in the BIOS of the computer.
Mar 08, 2011 | HP w1907 LCD Monitor
LCM-17v8 Monitor Blacks out after a few minutes. Unplug power source and you have display again, for how long is anyones guess. Any suggestions
Does this happen ONLY when connected to YOUR computer,
or does this happen when conected to some other notebook/desktop?
If the former, your computer is entering "power-save" mode,
after a few minutes of inactivity. Just "wake-up" your computer,
and it will wake-up the LCD monitor.
If it is the latter, then you have a "hardware" problem with your LCD monitor. Take it to a qualified technician for trouble-shooting.
Jan 13, 2010 | Westinghouse LCM-19v1 Monitor
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Monitor to black, power LED blinks, hard re-boot and it works
Take a look at your power saving settings. It sounds like the monitor is set to sleep after 20 or 30 minutes. You may want to change your setting to "never". The settings are under Control Panel - Power management
Aug 15, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor flashing at startup
When the monitor is flashing, is the flashing coming from the middle and going up and done to fill the screen. If so, probably capacitors in the monitors power supply are leaking and need replacing.
Mar 27, 2009 | ViewSonic VG900b 19" LCD Monitor
XP Computer Standby Feature Question
Have you disabled "Wake on LAN" in the power settings? There are also other settings in Power management that could affect this.
There should also be general settings for power savings such as "none" "medium" and "maximum power savings" With a little explanation of each.
Jan 27, 2009 | Computers & Internet
Incorrect power management
Dear u have a problem with VGA or Monitor...U should try to put new vga in you'r mother board and try.If still wont work then you have a problem with monitor
Oct 11, 2007 | ASUS P5LD2-VM Motherboard
Sceptre X9G-NagaIV 19" LCD Monitor Logo
272 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
