Question about Sony HVL-F32X TTL Flash
Can;t turn the tightening knob to mount the flash? Maybe the pin lock?
I have a sony HLV-F32X flash and can not attach it to the camera because the know is turned tight and it will not loosen.  There is a pin lock but it is raised as it should be.  Is there a trick to unlock the pin to loosen the area where the mount can slide on to the camera???
I'M UNCLEAR AS TO WHETHER YOUR ISSUE IS WITH THE LOCKING PIN OR THE COLLAR. STANDARD FLASHES, WITHOUT A "LOCKING PIN", A PAIR OF CHANNEL LOCK PLIERS CAN BE USED, AFTER WRAPPING THE JAWS WITH SOMETHING GIVING, LIKE ELECTRICAL TAPE, OR WRAPPED RUBBER BANDS. THE COLLAR CAN USUALLY BE LOOSENED IN THIS MANNER, IF IT HAS "BOTTOMED OUT" OR GOTTEN STUCK ON ONE END OR THE OTHER OF THE THREADED FOOT SUPPORT. IF YOUR ISSUE IS WITH A "STUCK PIN" THEN PLEASE DISREGARD THIS ADVICE.
Posted on Sep 25, 2008
Flash does not trigger
To make a guess as to what is occurring you have not presented enough information. So here are some things to try:
  • Make sure the flash is seated solidly on the camera. That is usually the issue.
  • With flash off the camera look at the shoe mount. Check the locking lever making sure when turned the center pin extends and retracts.
  • Sometimes the center pin does not engage the hotshoe
  • Clean both the bottom of the flash is clean and also the camera hot shoe.
Oct 16, 2013 | Nikon Speedlight SB-600 TTL Flash
I have been putting new expensive batteries in but is still spends a minute flashing orrange then flashes a red light and says "error" as if my batteries are dead??
Sep 11, 2011 | Sony HVL-F32X TTL Flash
Sony HVL-F32X manual
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this helps. Thanks for using FixYa
Sep 06, 2010 | Sony HVL-F32X TTL Flash
Ihave a sony flash DSCHVL-F32X whch I use on my Sony DSC-828. This has never given trouble but it now seems to refuse to connect to the camera
Try resetting the camera?
Other items you might have missed:
Fresh batteries in the flash..inserted the right way.
Is the flash indicating an error code? if so it could be bad connection between clash and camera.. Is external flash selected in the menu?
Jun 18, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
My knob has fallen off
sounds like the lockset has come apart in a way that it was not intended... normally you need to push a small spring loaded pin on the knob shaft in to remobe the knob, then a finished trim plate snaps off revealing the plate that gets tightened down to the face of the door... after tightening you snap the trim plate back on then the knob snaps on while pushing the pin in...
if it's a standard bedroom unkeyed lock then the plate and knob are one piece and the screws are exposed thru 2 holes on the inside knob...
Sep 02, 2009 | Kwikset Professional Door Lock...
Hot shoe plastic section broke on flash unit
I managed it by buying a broken (non-working) F32X from an auction service for something like 5 bucks. I just made sure (by looking at the photos) that the hotshoe was intact.
Here's how to disassemble and replace foot (I got to this by trial and luckily no error ^^).
  1. Unscrew 2 small screws located under the battery flip cover.
  2. Put the lamp (moving part) in the upright position.
  3. Unscrew 1 small screw above the infared sensor (below the main lamp part which you moved to the upright position).
  4. Remove the cover of the infared sensor by gently pulling forward.
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Pull them away from the casing just a tiny bit and use something to keep them in this position (I used 2 small nails). Then pull the pieces apart gently.
  6. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  7. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  8. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Took me about an hour to do this (most time was spent on trying to figure out how to disassemble the lamp), and the lamp works perfectly.
Warning: better test disassembly on the replacement lamp, since even if you break it, all you need it for is the hotshoe, so you can practice on it. Only after you learn how to disassemble the F32X do this on your working lamp.
Hope this helps!
-- Tomasz Andrzej Nidecki (tonid)
Jun 17, 2009 | Sony HVL-F32X TTL Flash
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
SB800
When you attach the flas to the camera can exidentli fire. This is normal, and manufacturer recomendation, turn off the flas unit before attach or deattach, prevent this fireing. Fireing when you turn the flashead is not normal. Probably the mounting foot of the flash unit can move in the hotshoe, breaking connections between the connector pins, causing exidental fiering. Always lock the locking lever of the flas, wich can prevent this unwanted movement. Also chek the hotshoe on the camera, wich should to have a "leaf spring" keeping the flash unit steady.
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
F828 32x Flash conx probs
Do you have the camera set for flash? If it were set for no flash (diagonal bar thru lighting bolt) the F32X and the camera do not communicate.
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
Sony HVL-F32X TTL Flash Logo
474 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
