Question about Samsung NV3 Digital Camera
The Samsung NV3
My Samsung NV3 turns off when trying to use the camera, but when I look at pics it works and says full battery. How can i fix this?
Well the soloution for this easy problem is just throw that camera away and go buy another one
Posted on Oct 06, 2008
Sdhc card used in samsung nv3 it says memory full
I don't think that camera (the Samsung NV3) takes SDHC cards. The same is true of many (perhaps most) cameras that were released more than a year or two ago.
You need to use a regular SD card, which -- as you probably know -- isn't any bigger than 2G.
May 20, 2010 | Samsung NV3 Digital Camera
I put a new memory card in the camera and it says
You need to eliminate the pics from the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the "format" thing again for the card. Everything should be normal now.
Apr 22, 2010 | Samsung NV3 Digital Camera
My samsung camera nv3 freezed after i removed memorycard while still on.please help me on how to fix this problem
Hi there remove the battery and put the memory card back. After that fix the battery again and press on button 5 sec. ihope your problem will solve then. Thnaks.
Mar 17, 2010 | Samsung NV3 Digital Camera
When I turn on my Samsung NV3 camera, the shutter opens, a blurry image appears on the LCD screen and then it turns its self off. Although the camera appears to be off, if you press the button to view...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 25, 2009 | Samsung NV3 Digital Camera
What do i do if my samsung nv3 camera wont charge
First, if you can, check the charger to confirm that it is outputting current to batteries. If the charger is working, your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may require professional repair.
Oct 20, 2009 | Samsung NV3 Digital Camera
Samsung NV3 wont turn on
take out an reinsert the battery...that works always for me.
Dec 18, 2008 | Samsung NV3 Digital Camera
I already uploaded pics on my samsung nv3 but it says no image..
take the external memory card out and see if they were captured on the cameras internal memory.
Aug 02, 2008 | Samsung NV3 Digital Camera
Nv3 turns off when i try to use the camera
Thanks MAN Your Slap things Worked man, I slaped My Camera twice and the camera fixed im so happy
Jul 13, 2008 | Samsung NV3 Digital Camera
Samsung NV3 Camera
Hey Rider18,
I would try taking the battery out and waiting a minute or two and then reinserting the battery. If this doesn't work I would have it looked at by an authorized service technician, or you could bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Samsung NV3 Digital Camera
Samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Apr 04, 2008 | Samsung NV3 Digital Camera
Samsung NV3 Digital Camera Logo
129 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
