1. Check which version of the AVIC-S1 you own Turn your device ON.
Press [MENU].
Touch the "Settings" tab, and then scroll the pages (select the arrow buttons) to find the "Product Information" button. It should be at the bottom-right.
Close all running programs on your computer.
Connect your AVICS1 to your computer using the supplied USB cable and turn it on.
Wait until your computer has detected your device.
When you connect your device to the PC, in most cases ActiveSync will start automatically and will ask you to set-up a partnership. Please select "No" if this happens.
On your computer, double-click the downloaded [update_V *_**_**. exe] file.
If the update process does not start automatically, open the folder containing the downloaded file by selecting "Start" on the taskbar, and then selecting Run on the menu. Enter the location you saved the downloaded file and click OK.
The update process will start automatically.
Click OK and disconnect the AVIC-S1 from your PC.
Make sure that you have installed Pioneer Sync Manager from the DVD-ROM that was supplied with your device.
If you have problems connecting your device, please visit the Microsoft support website.
During the update process, you should not disconnect the USB cable or the AC adapter, turn off the device, enter into standby mode, or reset the unit or shut down the computer, enter the computer into standby mode or restart the computer.
4. Check that the update has been successful:
Turn your AVIC-S1 on.
Press [MENU] to enter the top menu.
Touch "Settings" tab, and then turn the pages to find the button "Product Information" by touching the triangle mark at the bottom-right.
Touch "Product Information". If the version on the screen is now "1.01.14", your device is corr
If you need further assistance please post another question.
Thank You Please Rate My Solution if you found this helpful
Jayson
Hello there! I think that I could help you, email me: service(at)gps.pol.pl
