Question about Dayton 3VU34 Heater
Termostat knob broke down on dayton heater 3vu34
Need new termostat
2 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: replacement knobs??
contact grainger.com. they can get any Dayton part.
Posted on Feb 24, 2010
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Where can I find a replacement base board thermostat knob ? The knob is beige. SEKNOBI KIN SE- Knob-I IV Knob F / S22. Regulates a base board heater.
Dayton Heaters are a product of Grianger Industrial Supply. The have locations all across the US & Mexico or you can find them online http://www.grainger.com/Grainger/wwg/start.shtml
Hope this helps you find the replacement knob.
Apr 12, 2011 | Dayton Electric Heater
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Have Dayton 3e227a gas heater fan has quit, need new motor, can you supply source to buy? Tim
Dayton is a Graingers Brand. Go to the site below and I'm sure you can find your part. Put in your Part Number...Jim
http://www.grainger.com/Grainger/rp_parts_home.jsp
Feb 18, 2011 | Dayton (3E227) Gas Radiator Heater
Electric heater element
If parts are available for that they would be at www.grainger.com
heatman101
Nov 19, 2010 | Dayton 3VU34 Heater
Replacement knobs??
Feb 24, 2010 | Dayton Electric Heater
240v circuit wiring to run my new Dayton Heater (3Vu34A)
On the 40 amp breaker, you should be using 8-3 w/ground. 10-3 w/ground will work on the 30 amp breaker. 12-3 w/ground is used for 20 amp circuits. Your new heater should have the electrical requirements listed in the user/installation information.
Jan 29, 2009 | Dayton 3VU34 Heater
Dayton 3e239e looking for operation manual
Normally you turn the gas valve to the pilot position, light the pilot, hold down the gas valve knob for 30-40 seconds and release. If the pilot will not stay lit replace the thermocouple. These are available ay Home Depot.
Ray
Dec 06, 2008 | Dayton (3E379) Heater
Torpedo heater lights and runs with control kknob pressed in but shuts down when control knob is released.
Change the thermocouple. The thermocouple scenes the heat from the pilot lit and signals the main gas valve to remain in the ready condition. The main valve will not receive the signal if the thermocouple is bad and will revert to the safety shut down when the control knob is released.
Nov 20, 2008 | Dayton Heating & Cooling
Dayton 3VU34 Heater Logo
71 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
