Question about Microsoft Xbox 360 Console
Zone code got this xbox360 from hawaii and some of the games and dvd doesnt work.its say need to change the zone code.i have no idea.
  • Anonymous Sep 26, 2008
    My xbox wont play my GTA and it says this disc's region code is incorrect for this console.
  • 34 Answers
    1. Determine whether the game disc is from the same region as the region where you purchased the Xbox console. To determine the region, view the back of the game package. Look for one of the following codes:
    2. NTSC: North America and South America (United States, Canada, Mexico, Chile, and Brazil)
    • NTSC-J: Asia (Hong Kong, Japan, Korea, Singapore, and Taiwan)
    • PAL: Europe, South Africa, India, Australia, and New Zealand
    1. If this symptom occurs with only one or two discs, search the Microsoft Knowledge Base (http://support.microsoft.com/search/?adv=1 (http://support.microsoft.com/search/?adv=1) ) for the specific game title or titles. If you find a known problem, follow the instructions in that article.
    2. If the game disc worked in the past, the disc might now be dirty or damaged. Clean or replace the disc to see if this resolves the problem.
    3. If this behavior occurs with only one or two discs and no known problem exists, return the disc or discs to the retail store where you made the purchase.
    4. Turn off and unplug your console, remove the Xbox Hard Disk Drive (HDD) and any attached memory units (MUs), and then reconnect your console. Try the disc again. If this procedure seems to resolve the problem, turn off and disconnect your console, reattach the HDD and any MUs, and then delete any saved games for the game with which you had problems.. Note If you can do this, move the saved games to a different memory unit.
    5. If you have this problem only with original Xbox games (games that are designed for original Xbox, not Xbox 360), the original Xbox backward compatibility update may be missing from the HDD. To resolve this problem, download and burn a copy of the backward compatibility update to a disc, and then install the update to your console
    Posted on Jul 19, 2009
    I brought my phone from hawaii and i tried to service it but it cannot. the only thing that needs to change is the hawaii frequency or service to american samoa frequency service. So, how can i change the...
    If the phone is tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
    Nov 01, 2011 | Palm Treo 700wx Smartphone
    In my PES 11 on my xbox 360 , it doesnt start .... when i put in the disc it says region error . SO how do i fix it?????
    For the xbox360, the region code on the disc must match the region code in the registry of the dvd-rom drive. The only way around this is to modify your xbox360 so that it plays different regions. This is highly illegal, voids all your warranties and is not at all recommended.
    I own a US console (NTSC) and it will only play discs that match with the NTSC code. I can not play a Japanese game (NTSC-J) since NTSC-J is different from NTSC.
    Use the following link to figure out which region disc and which region xbox360 you have:
    http://support.microsoft.com/kb/906934
    Mar 28, 2011 | Konami Pro Evolution Soccer 2011 for Xbox...
    Xbox360 can't read disk, we have tried blowing inside it, but for some reason its not reading any of my xbox360 games
    worst thing you can do is blow air i recommend opening dvd drive then get yourself some q-tips then clean lens with alcohol if that doesnt work you might need a new lens or drive
    Nov 14, 2009 | Microsoft Xbox 360 Console
    Only Mass effect freezes my xbox360. It happens
    There are two things you can try..
    One method is to run a cd and dvd lens cleaning disk inside the Xbox itself..
    The second method is to try cleaning the Game Mass effect itself.. Use one of those cd cleaning kits on it..
    If it still doesnt work, then try borrowing or renting a copy of the game and see if the other copy will work..
    Oct 30, 2009 | Microsoft Mass Effect for Xbox 360
    To zip code for hawaii
    HERE is a full list of Hawaii zip codes.
    let me know if i can help you further.
    Sep 10, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
    Xbox360 can't play dvd game only dvd movie or cd
    this is a common problem faced in xbox360..you have to use original DVD else the low quality DVD leads to damage your xbox360 lens...for further reference click here for repair guide....
    Sep 04, 2009 | Microsoft Xbox 360 Console
    Xbox will not read any game or dvd
    It sounds like your DVD drive has failed, this is fairly common. There is a good chance it is still under warranty from microsoft. Give them a call at:
    800-4-My-Xbox
    If it is not under warranty you can replace the dvd drive itself, google xbox 360 replacement parts. It's not too difficult if you are technically inclined.
    Jun 25, 2009 | Microsoft Xbox 360 Console
    My xbox360 does not red new games
    maybe yu got to update go call xbox .
    Jan 07, 2009 | Microsoft Xbox 360 Console
    Xbox Does not play original games
    Error Codes XBOX360
    http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
    Feb 25, 2008 | Microsoft Xbox 360 Console
    How do I re-flash dvd drive for xbox 360
    did you just buy a dvd drive or os it an xbox360 dvd drive?
    I think this might be what your looking for.
    http://www.llamma.com/xbox360/repair/hitachi-disassembly.htm
    Dec 11, 2007 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    88 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
