Question about Alpine CDA-9855 CD Player
Face After a few seconds the face goes blank (the LCD screen). Everything else works fine. I think it just started randomly.
I have a problem with mine the screen doesnt work but everything else does you can see the green lights and everything but just the screen is blank can you help me
Posted on Jul 17, 2009
I had this problem the other day too, I found that if you hold down the function key and press the source buttom it brings up a preset options usually set to 65 use the down to to change to say 6b and it stopped going off, this might help I hope it does.
Posted on Jul 07, 2009
A har i know this 1 because i had the same problem its a little chip in the face u can get it fixed for about 25 quid, I got mine fixed but it ended up only lasting a few days turns out something was burning it out for the cost of diggin any further it was just best to buy a new front.
Posted on Jul 06, 2009
    Problem Solver:
  • 9 Answers
Make sure that the face is properly and securely attached. If the face goes blank and the music cuts out you may have a loose pin in the harness. You should pull it apart and test this with a multimeter. A simple solution if this is the problem may be to hardwire that loose pin directly to the opposite connecting end. Good luck
Posted on Nov 17, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Feb 20, 2009 | Garmin Forerunner 205 GPS Receiver
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
Screen
if evrything ok in your fone except the screen(LCD). the problem is your LCD maybe its just a lose contact or or the LCd is broken maybe it can help to you ^_^
Sep 27, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Razor phone srceen goes blank after a few seconds
This is the Early signs of Failure! Just had to Upgrade my RAZR for the same Problem. Your Options are (1) Have it Repaired-Costs a LOT! (2) Upgrade to a New or Refurbed Razr. There are no other Solutions
Aug 09, 2008 | Motorola Mobility RAZR V3
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
LCD screen
take the face off and press the reset button -if this does'nt correct the problem remove the power harness for about a minute or so put the plug back in and try again-if this does'nt help send me an e-mail at merle840@aol.com
Mar 27, 2008 | Virtual Reality VRCD500-SDU CD Player
Alpine CDA-9855 CD Player Logo
304 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
