Question about Dishwashers
Dishwasher accumulates a pool of water long after use
  • 409 Answers
if the water is outside of the d/w, on the floor infront, you may need to have the door gasket replaced
if the water is inside in the tub, the d/w is not draining. check the drain pump for anything caught in it, like coins, hair or food pieces.
can you provide me with the make and model off the dishwasher?
Posted on Sep 25, 2008
Door does not open to dispense soap
Often times the latch needs cleaning from the accumulated calcium and soap caked around the latch. Use an old toothbrush or sometimes something a little stiffer to scrub around the latch, the dispenser cups and in the general area. If there is still accumulation a small amount of CLR [calcium-lime-rust] remover will break down the accumulation. We had a Kenmore running in very hard water situation that wouldn't open and we just left it open and didn't worry about the dispenser door releasing. We did this because we always scraped off all the food in the sink before putting dishes in the dishwasher and then ran on the water miser setting which requires only one of the soap dispenser wells to be filled.
Nov 04, 2010 | Kenmore 15954 Built-in Dishwasher
Frigidaire dishwasher PLD2854rdc2 Water seems to pool up at the bottom an never completely drain out. I have cleaned out any accumulated food but doesn't seem to drain.
you are supposed to have a small amnt left in bottom about 1-2 inches it keeps the motor seal wet so it will not dry out and create a leak that could cause more damage
Dec 25, 2009 | Frigidaire PLD3460REC Dishwasher
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
My ge dishwasher will drain but after a few hours
Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
Jul 07, 2009 | Dishwashers
After 2 minutes top washer blinks. Water does not drain
When I opened the top drawer the water seems to be accumulating in the drawer and no water is draining. The drain tube appears normal and not kinked in any way.
Jan 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Lime? deposits remain on base of stemware, cups, glasses, etc.
Your water softener may not be working properly. You may have to wash glasses by hand to remove accumulation.
Nov 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
G865 - Constantly draining
Your problem is a water leak.  There are a couple of rubber seals that are required to correct the problem.. When the seal leaks it accumulates in a tray in the bottom where a sensor turns on the pump when water is present.  If you remove the lower access panel and reach in you should see the accumulated water.  I had a repair tech repair mine.
Aug 20, 2008 | Miele 24 in. G865 Built-in Dishwasher
Dishwasher Accumulates Water When Off
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
Nov 08, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
