My netgear cable/dsl web safe router RP614 v4 isn't connecting to the internet. When I plug straight into the modem it works. But through the netgear neither of our 2 computers work. The lights are on, but the signal isn't getting through
Ryutut
Posted on Sep 25, 2008
How to setup a wireless network for xbox live using embarq 660 series modem and netgear wnr2000 wireless router
Here is a link to setting router up to use with xbox it is a different router however it should be the same concept hope it helps just read the forum http://forum.teamxbox.com/showthread.php?s=&threadid=135051
Oct 02, 2010 | NetGear -DSL Web Safe Router/ RP614 -...
We setup our router and it works for the computer and 1 laptop but i cant get my laptop to connect to the internet.
if you are able to connect to internet with your desktop and not connecting through laptop, i suspect there is a problem with your laptop's Port settings.. run these commands in command prompt. (run -> cmd)
1. netsh winsock reset
2. ipconfig /flushdns
after this, windows firewall should be turned off. Then try to reconnect your WLAN. Give suitable WEP Key if you got.. Then Browse.. Be sure that your Laptop lies in connectable distance from Router. Good Luck
Jun 09, 2010 | NetGear -DSL Web Safe Router/ RP614 -...
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolved your issue
Happy to help
Thanks for using Fixya
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
Won't logon to internet through the router...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 16, 2009 | NetGear Cable/DSL Router with 10/100 Mbps...
Twice after using Google's gmail video chat with our RP614, our internet access stopped. I had to recycle the power on the RP614 each time. Is this a known issue?
I can't think of a connection between the two events, esp if it happened only twice. I own a similar Netgear router (wi-fi tho and not DSL), and find it very reliable.
Nov 07, 2009 | NetGear -DSL Web Safe Router/ RP614 -...
How to connect ruoter to internet
If you are connecting to either broadband cable or dsl you pretty much have the same steps. First hook up the modem (dsl or cable) with its own power cable and its own internet connection coming in (dsl will be a usually green phone cable)(cable will be a coaxial line that the cable guy already hooked up). Next get the netgear router and plug in its power cable somewhere near the modem, then plug in a preferably crossover ethernet cable to the uplink connection on the back of the netgear, should be on the same side as where the power cable went in. (and yes you can probably use a straight ethernet cable as well) Plug the other end of the ethernet cable into the only location it will go on the modem, both boxes should already be setup for use, if for any reason they do not work just pull the power on them both at the same time and wait a minute or two and replug them back in for power resets.
Oct 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
Router wont connect to internet
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://192.168.1.1 or http://192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
From the above configuration, please check if you can now access the Internet.
Apr 26, 2009 | NetGear -DSL Web Safe Router/ RP614 -...
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
The light of internet is orange,not yellow.
The router should have reset button on the back. This will reset it to factory defaults. If you have an ISP that gives you internet without a username and password like rogers then you should be good to go. If your ISP is like Bell then you will need to get into the website of the router and configure it.
Nov 28, 2008 | NetGear -DSL Web Safe Router/ RP614 -...
Carnt get ower rp614v3 router to work
Look for a factory reset button (pinhole) near the power port. Use a paper clip or something to hold it in for about 10 seconds. That might recover it.
Nov 25, 2008 | NetGear -DSL Web Safe Router/ RP614 -...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
