Question about Refrigerators
Refrigerator caught on fire.
It sparked and caught fire at start device combination relay and overload.
Can it be fixed or are there other problems that may have caused this to occur.
Im a little reluctant to fix it, thinking the problem my reoccur when I am no
not at home and cause a major house fire.
  • Texasav8or Jan 12, 2009
    I have a 2001 Superba side by side. Something on the compressor caught fire and filled the house with smoke. Called 911, etc. Kitchenaid will have their safety rep call us. Sears repair guy will be out for an astimate to repair. Could have caught the house on fire.
    President:
  • 1,462 Answers
Start relays smoking is a common fault and does not usually indicate a fault elsewhere. parts are reasonable cost so give it a try
Posted on Sep 25, 2008
Asd2522wrb04 amana side by side refrigerator. clicks like it is coming on. then goes off. nothing freezes or cold. Why?
I believe what is happening here is a defective start relay and overload. Right now I would pull refrigerator away from the wall and unplug. Next remove the cover over the compressor feel top of the compressor and if it is not possible to keep your hand there from heat tells me the compressor is trying to start. Keep unplugged until replacing the Start Relay Kit below.Most times the compressor that begins to do these symptoms can be fixed by replacing the=>
W10189190 Relay and Overload Kit
These parts can be found by removing the rear cover near floor and then pulling the cover on the side of the compressor. Click Here=> ASD2522WRB02 Unit Parts In that photo is a compressor top left of photo. Number location 13 is the cover of the part I am talking about and location 12 in that photo is the start relay and overload. If you have trouble I will be here to assist you, Thanks Sea Breeze
Sep 26, 2011 | Amana Refrigerators
Every thing runs but the compressor wont fire i think its the compressor start up capacitor how do i test the capacitor
first discharge the capacitor for safetys sake,then touch the meter leads of a multi-meter set to RX100 to the caps leads if the needle stays on 0 the cap is shorted(but that would trip the wall breaker),if it doesnt move at all its open,if it goes to 0 and slowly climbs back towards infinity its good,i believe you will find the ptc overload relay on the compressor is defective,its in combination with the capacitor,the cap is only on there to take the power spikes off the relay contacts during start-up,the ptc overload relay is what aids in compressor start-up/run/and overload protection if compressor wont fire,change them both and it will run
Mar 22, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
When getting water from the front of the fridge there is a leak at the bottom from the hose...how do I fix it?
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. A hung up ice maker was the culprit for this overload most likely. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 10, 2010 | Maytag MZD2766GES Side by Side...
Cat number ED25TEXHW00, side by side, Whirlpool Refrigerator. Neither fridg or freezer will cool. Lights turn on & condens fan runs. Compressor will not kick in. What to look for???
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
May 30, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Jan 16, 2009 | Whirlpool GS6NBEXR Side by Side...
tough call but. the entire start relay kit and cap can be replaced. it is usually surrounded by metal and if it does fail is not a major source of concern as far as a fire. stink yes, but nothing around it to flame up and cause a major fire. performance can be checked immediately after parts are replaced, and if it starts ok then you are as safe as you would be with a brand new unit if it had the same problem!good luck
Dec 07, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
May 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Unit isn't cooling
check the relay/overload that "gurgling" could be a compressor trying to start.
you can replace the old relay/overload with a supco combination relay/overload
Apr 25, 2008 | Refrigerators
HOTPOINT RLA30 FRIDGE
is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Apr 21, 2008 | Hotpoint RLA30 Compact Refrigerator
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
