Question about Logitech Z-5300 Computer Speakers
Constant loud muffled noise coming from the sub and speakers.
There is a constant loud muffled noise coming from the subwoofer and speakers even if no song is playing. It used to work perfectly and then randomly this happened. I never dropped it, didn't spill anything on it...nothing ...the only thing that makes sense is dust being collected inside.
Oh and at first only the front left that had the muffled noise and then within a day or two the whole thing became like that.
Just to clarify: if i turn the system on without anything plugged in there is that loud muffle noise...
Oh and btw, the fuse is fine.
  • hnpetrosyan Sep 26, 2008
    Which jack are you talking about? I tried using a different controller and the muffled rumbling was still there so I'm pretty confident the problem is from the sub itself.
    What can I do to fix it?
    Oh, ok...well the jack doesn't matter. Even if I dont plug anything in (other than the controller) it still has the rumbling noise coming from the subwoofer.
    How can I fix it? Can I send it in and have it fixed? Can I buy specific parts and do it myself? I got it for $180 (or whatever the price was) and losing it would be a real bummer.
    Problem Solver:
  • 6 Answers
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Posted on Sep 25, 2008
  • clyde36067 Sep 26, 2008
    the jack you plug into comp for speakers. sub is on of course.. you may have blown the subwoofer.
    Most likely cheaper just to go buy one at walmart or something for about 80 dollars, 70 to 75 watts. That includes subwoofer and speakers. To fix it you would need to replace the subwoofer.
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Loud noise coming from subs
All of the vibration from the subs rattled something loose, Most likely is the speaker to enclosure fasteners but it could be the case itself, internal baffles or even the speaker frame itself is coming apart.
Jan 31, 2015 | Audio Players & Recorders
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Wierd problem with my subwoofers please help
It sounds like your RCAs are pickin up noise somewhere, are your rca cables next to your amp power wire? this could be the problem. Just recheck your signal wires and make sure they aren't close to any significant power cables. Also does the noise only come from your subs or your car speakers to? If it comes from all your speakers you may have a headunit problem... hope this helps
Sep 30, 2009 | Orion 12DVC Car Speaker
Subs not working.
blown sub if it sounds liek a cracking, with sub off, gently press the sub in, if you hear noise, its dead
Sep 23, 2009 | Car Audio & Video
What cause subwoofer to make constant noise(loud)
usely it turn out to be a ground issue make shure there are grounded with the PROPER guage of wire or heaver the required
Jul 15, 2009 | Infinity BASSLINK Car Subwoofer
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
Noise comming from centre speaker of panasonic scpt560 home theatre system
check the cable 1st. If this speaker is powered, you could have a bad shield, or the power is causing a ground loop.
If the speaker is coming from an amp using speaker wire ie: 2 lead + - check the connection and make sure no fraid strands are touching each other on the rear connection.
In addition check your TV, Ap, And speaker system (if sub is powered independently) are all on the same curcuit.
a certain cause for ground looping resulting in hum.
Jun 24, 2008 | Audio Players & Recorders
100watt sub
There is a problem wwith teh power supply or the amp section. Does the noise remain constant or does it vary in volume? The sub should have a level control, does the noise vary with that control?
Dan
Mar 19, 2008 | Kenwood SW-38HT Subwoofer
Logitech Z-5300 Computer Speakers Logo
942 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
