The picture on my old slyvania consoul set has become a bunch of snow but.
I have an old slyvania form 1984 model #27470636. The picture is just a bunch of black lines and snow but I still have perfect sound. Can I fix it or is it jut done for?
  • 927 Answers
Good Day;
1984 > 1994 > 2004 > 2008 = ?; YOU are wondering WHAT? With the new tech of today and HD coming in spring of 2009, I think it is time you look for a new TV. Please give it a good resting place.
Good Luck, big IRISH.
Posted on Sep 25, 2008
NES help
This is possible a problem with your A/V cords. Try "jiggling" them around when you have the NES turned on, and if there is no picture or sound after that, you may need a new set of the cables.
Jun 19, 2013 | Nintendo NES Console
Philips 32 Ambilight PF 9986 TV Picture Problems - Fuzzy & Loss of Picture
What are you using for signal to the set? (Box?) and how are you connected? (HDMI?)
If HDMI try going Component
It may be the box/HDMI hook up causing the problem.
Mar 15, 2012 | Televison & Video
I am trying to take the consoul cover off my 2007 four door jeep wrangler, I cant get the knob off the 4x4 shifter so the consoul cover will come off. How do I remove the shifter handle.
some just unscrew, others have a set screw which is hard to see sometimes, it would be at the bottom of the knob just look around the bottom rim of the actual knob itself, you will see a small hole, inside that hole will be a set screw that you need a little allen wrench to loosen it,, once you've done that , it should come right off ( depending on the knob, there could be up to 3 of the set screws so look carefully)
Aug 02, 2011 | Jeep Wrangler Cars & Trucks
Need remote code for slyvania lc155sl8p
try these
Sylvania 0 0 5 4 ,0 0 3 0 ,0 0 9 6 ,0 0 2 0 ,0 3 8 1
Please apply a rating to my help[++++Thank for using FIXYA
May 21, 2010 | Sylvania Televison & Video
Ice forming in freezer refrigerator not getting cold
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Nov 20, 2008 | Whirlpool GS6NBEXR Side by Side...
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Games wont load
Hi, I will need to know if you have ever dropped your consoul before or have come in contact with water. My friend had this happen and it wasn't fixable but there could be another problem. How old is the consoul, and are any of the games you have dvd format. There could be many things that are wrong or broken so I suggest that youo call Sony at this number: 1-800-222-7669
Hope this helps!!!!!!!!!
Aug 27, 2008 | Sony PlayStation 2 Slimline Console
Sony tv snow for first 5 minutes on
Probably dry solder joints in the tuner section.
When the set warms up, the faulty joint/s make contact, then lose contact again when it cools down.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
