Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips Blue Shadowing
Our 60" Philips TV has blue shadowing and line bending in the lower left and upper right corners. Otherwise the picture and colors are fine. Is there anything short of spending a lot of money on service that we can do to correct the issue? Thank you.
    Problem Solver:
  • 9 Answers
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Posted on Sep 25, 2008
Philips 60PP9363H Blue shadow and Sensors not verified
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
Check the blue horizontal convergence amp on the convergence panel.
Whether or not this is an in house solution, is up to your experience in electronic repair and specifically TVs.
Good luck
Sep 08, 2008 | Philips 60PP9363 60" Rear Projection...
Blue shadowing r/h corner and center of picture
You need to replace the optical block. Sony may pay to have the part replace.
Sep 16, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Shadow issues
You need to replace both convergence ICs they are both STK392-110 you can get replacement ICs at the following link with free instalation Instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Philips 50P8341 50" Rear Projection...
Philips model 60PP920217F
You need to replace both convergence ICs STK392-120 they are an easy repair you will also need (4) 6.8ohm Convergence resistors. You can get replacement ICs and the resistors at the following link and they will provide free installation instructions and free on line tech support so you will be able to do the repair yourself and save about 400.00 for a 45 minute repair. heres the link.
Apr 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Blue wave shadowing
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Feb 08, 2007 | Hitachi 43FDX01B TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
