Question about Refrigerators
Ice making problem
I emptied my ice bin twice and now my re frig will not make new ice. I have water coming thru the door. The bin seems to be put in right. I have emptied the bin before now problem. What am I doing wrong. My refrigerator is 1 year old.
  • jjorcj Sep 25, 2008
    Robert this a thru the door with a switch. There is no arm. I removed to empty ice and we have looked at all the steps in our manual. Turned the switch off and on.
    Thanks for reply
    Problem Solver:
  • 13 Answers
There is a metal wire that gets pushed up when the Ice becomes too full and turns off the ice maker. You can pull it back down with you hand and that will unlock it and turn the ice maker back on.
Posted on Sep 25, 2008
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Whirlpool 2211590 Ice Auger Conquest 2-door side-by-side Part #: 2211590 ice cannot come out through the dispenser & will not crush ice....freezer still makes the ice....motor runs slowly &...
If the ice will not go down the delivery outlet. the the augar will have to work harder than .normal .. try drying the out the delivery area // then use a food grade silcone and spray this . this may correct problem .. . also ck the seal on the door if bad it will let mosture in and cause poor delivery .. hope this helps mm. feed back pls ..
Jul 10, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirpool side by side frig WITH DOOR ICE MAKER and need to know how to get AUTOMATIC ice maker in so door will shut model ED226WXFW02
looking at your model the ice maker is mounted and is not removable . so maybe you mean the ice storage bucket. . make sure the rails are clear and it should slide in and when all the way in lift up and feel the click into pos . this lock the bin so the augar can work . and the door should shut .. hope this hepled mm and thanks for using fix-ya ..
Oct 16, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Codes flashing on door screen after power blip
You had a power surge due to the storm, unplug the unit for 5 min's and see if it resets the faults.
Jul 09, 2017 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
Water is not coming out of the dispenser. Frig is
Good day,
4 hours is no ware enough time. As well, turning the freezer to a warmer temperature does little, since you're only changing it by a few degrees.
Forcing anything thru that tube, if it's ice can result in a difficult and expensive repair.
No body likes this, but shutting the machine off (unplugged), leaving the freezer door open with a floor fan blowing on the inside of the door is safe, but inconvenient.
Nov 15, 2009 | Frigidaire FRS23R4A Side by Side...
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
The ice maker stopped working on my Kenmore Mod 106.55532400
either your water valve is clogged or it has gone bad, located bottom right corner, you can take it apart and check the screen filter if it is not clogged than you need a new valve approx 72-80$ plus install unless you diy!
Nov 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Whirlpool refrigerator model et22dq. The ice maker makes ice and dumps it but won't dispense thru the door. It seems to freeze in the ice bin. Could there be a water leak inside the ice maker?...
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
Nov 21, 2008 | Whirlpool Refrigerators
Whirlpool Frig
There could be so many different things that cause the problem. Service cost a lot of Money and I can think of about ten different reasons why the ice maker isn't doing it's job. If I was there I know I could find the reason. Like poor air circulation around the ice maker, restrictions in the water flow to the maker, low freezer temp., door gasket leakage, etc. It may be more cost effective to purchace a new fridge with the features you want and need.
Oct 22, 2007 | Refrigerators
Refrigerators Logo
191 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
