Question about Denon AVR-2307Ci Receiver
Denon AVR-2307CI No Display on Receiver
The receiver display "blacked out" the green power light is on and everything functions properly. Any idea how to turn the lights back on the display?
Thanks.
  • 5 more comments
  • Anonymous Nov 18, 2008
    Hi i've have the same problem
    Marcel
  • peepoop Dec 20, 2008
    Same problem here. I fixed it by unplugging the power for two weeks.
  • kimmj Jan 01, 2009
    I have the same problem--the receiver works but no display
  • WdlsBadPuppy Jan 05, 2009
    Ditto
  • peepoop Mar 06, 2009
    I sent my 2307-CI to Denon's west-coast repair center twice for this very same issue. Both times they told me that they were unable to duplicate the behavior and that I was basically a crazy person.
    It worked when I received it back from them. Of course it broke again in the same manner just a few weeks later. Repeated the whole process. I'm crazy, nothing's wrong, etc.
    A system reset won't fix it, and the dimmer button does nothing.
    Now it's out of warranty and I'm left with a dark receiver.
  • jim2686 Mar 11, 2009
    Same problem here. It initially displays the line of icons across the display, then if you hit the dimmer switch several time, it goes totally black and stays that way. System reset didn't solve the problem. Sent back to the factory where they did a firmware upgrade, but 2 weeks later it did the same thing. Brought back into the local store and it was still in a failing state, but when they took it to the local repair center, everything worked fine. 2 weeks later it failed again.
    Denon has a bug somewhere in the code.
  • Anonymous Mar 13, 2009
    I have the Denon DRA-425, but problem sounds the same. Main display went out, but green power light is still on and all the source lights still work.
SOURCE: avr receiver
I had same problem with my denon avr 1601.I have fixed it by myself by favour of Haapy Yogy. Thank you.
Posted on Feb 19, 2008
  • 54 Answers
SOURCE: Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Posted on Apr 08, 2008
SOURCE: my denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Posted on Jul 17, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
SOURCE: Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Posted on Jan 10, 2010
No power ; no display
sounds like you might have a bad power transformer.
Aug 07, 2014 | Denon AVR-1907 Receiver
Can I make the Denon AVR-2307Ci receiver have a passthrough for 3D?
I believe it is like my Denon AVR-3808 as it's a HDMI v1.3 compliant. For 3D you need 1.4. So I now use optical cables to the AVR and HDMI to the TV. Then config the DNLA player to split the video to HDMI and the 5.1 sound to optical.
Jul 15, 2014 | Denon AVR-2307Ci Receiver
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
I reinitialized my 2307ci receiver and cannot get on on screen menu
I had a similar issue with another denon model solved it by buying a cheap replacement remote for denon multiple models, make sure it covers your model. It looks better than the old one and covers every function.
Dec 23, 2013 | Denon AVR-2307Ci Receiver
Denon AVR-2307CI HDMI won't always connect
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
Aug 23, 2009 | Denon AVR-2307 Receiver
I just hooked up my wii to my Denon AVR-2307CI receiver and have video but no audio. I set component in assignment to VCR-1 and put Green/Blue/Red in comp 1 and Red/White in VCR-1 in Audio IN
Most likely the VCR1 input in the Denon is set to a digital input, you will need to go into the setup for the VCR1 input and make sure that NONE is selected for the digital audio input.  Also - make sure you did not plug the Red/White audio cables from the Wii, in to the VCR OUT, instead of IN.
Mar 10, 2009 | Denon AVR-2307Ci Receiver
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
My denon reciever display wont't work
Jun 23, 2008 | Denon AVR-2805 Receiver
No display
I too have mine for 1 year and all of sudden it powers up for stanby and sound is produced but no display?
May 15, 2008 | Denon AVR-2307Ci Receiver
Open Questions:
Denon AVR-2307Ci Receiver Logo
1,074 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
