Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Sound of water dripping on something hot
Tonight we started hearing water dripping at a fairly high rate from our fridge. I opened up the freezer side and began to hear the sound of water sizzling, like the drips were falling on something hot. We have been in this rented home for 6 months and not heard it make this sound. It lasted for about 5 minutes. I pulled out the bottom drawer of the freezer side and looked to the back to see a metal plate behind a white plastic grid. This seemed to be where the water was dripping to, but when I felt the plate it did not feel hot. Can "cold on colder" make that sound? Any idea what the sizzling sound might be? Thanks.
  • 1,462 Answers
Don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Posted on Sep 25, 2008
The ice maker quit a few months ago (water still works) but I hear dripping into the drip pan.
sounds to me that ice tray fill tube is broken in the back as it runs up from the bottom to the tray , could that be the source of the sound of running water u hear ??? ill bet its intermittent , say 30 sec every two hours ??? and it stops making sound if u turn off ice maker ??
May 04, 2016 | KitchenAid Superba KSCS23IN Side by Side...
Sub Zero dripping noise from freezer when cycles off
Is this noise periodically or every time the fridge cycles off? Does it sound like water dripping on a hot surface?
Sub Zero Repair Tucson
Dec 05, 2012 | Sub-Zero 650 / O Bottom Freezer...
My fridge works fine but sometimes the freezer will stop working and you can here a sizziling sound coming from the back like water dripping and hitting something hot. I unplug and plug back in and it...
Hello, welcome to FixYa.
This is just the normal operation...specifically the defrost cycle every frost free unit must cycle through every 8-12 hours.
You are correct, the sizzle is water (from the melting ice) dripping onto the defrost heater. It is all normal so no need to worry.
Thank you for choosing FixYa today. Please take a moment to rate your experience here.
Macmarkus :)
Aug 15, 2011 | Kitchen Ranges
I have a Kenmore side by side that is not cooling the way it was yesterday. The fan & compressor are working but its not blowing the cold air into the fridge or freezer. In the freezer, I hear as the...
It sounds like you are refering to the defrost cycle. This would make the noise you hear. Try cleaning the condensor coils and the fan that is in the bottom where the compressor is. This may help. let me know. have a great day.
Apr 27, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
I have an older admiral refridgerator, when you open freezer it sounds like water dripping on a hot skillet. I unpluged it, later pluged it back in and wont come on
The sound was water dripping on the defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
Water dripping in the freezer We have side by side kenmore fridge and freezer and filtered water. I just opened the freezer and heard dripping of water behind back cover. It sounded as water is hitting...
this IS normall. the freezer is just in defrost cycle. the heat elements are on and defrosting the evaporator. you are hearing the water hitting the elements and running to the drain. this is normall, does it every day, just the first time you happen to notice it. shane
Aug 25, 2009 | Refrigerators
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Hot coil?
Hello gaylekell,
Welcome to Fix ya
You said, you just opened your fridge a minute ago and it sounded like water or something is dripping on a hot coil at the bottom back of fridge.
It is in the auto defrost mode!
All frost free or self defrost refrigerators use this method of dispersing the water into the air as vapor.
As the water accumulates below the fridge is supposed to blow the water onto the hot coil or compressor and evaporate it away. That's why there are no more drip pans to empty!
If you do not notice any problem in the operation of your fridge
and it is not excessively loud, (Which I do not think it will be under a normal situation )
Your fridge is more than likely running normally and fine!
How old is the fridge and what's the model number?
Thank You for utilizing my advice, Huuum
Please remember to leave a rating!
Oct 03, 2008 | Danby Designer DAR1102W Refrigerator
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
1,030 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
