Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD 57733 picture color problem
I have a mitsubishi WD 57733 tv that was manufactured in july 2007. Last night it stopped recieving the HDMI signal from the satellite reciever and when I switch over to DVD input (component input) the picture looks saturated on all of the highlights (sort of like switching your computer back to only showing 256 colors). I tried another DVD player (component input) and it does the same thing. I tried adjusting and resetting all of the display/color options and nothing clears this up. After reading some posts here about other sets and retrieving fault codes, I pushed input + menu and recieve 009.01 in the upper right of the menu. The brightness seems fine. Any ideas anyone?
  • flat4 Sep 30, 2008
    Thank you for the reply. I have tried the unplugg power reset of both the TV and the sat receiver and nothing has changed. I also have another dish receiver (hdmi out) and the TV still does not receive a signal through the hdmi input. Picture is still the same too.
  • 927 Answers
Good Day;
Try resetting both devices TV & BOX, unplugg power for 2 to 5 minutes then plug back in.
good Luck, big IRISH.
Posted on Sep 28, 2008
  • MICHAEL MULLINS Oct 01, 2008
    Good Day;
    WHAT "ID" did I mention in my post, weak signal or somthing?????? Please explain, I think you read wrong "FIX", this what i inputted;
    Sorry you are having a problem with the TV, but this a very common problem this model. Please try this: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
    Good Luck, big IRISH. PS UOK?
My WD 57733 will attempt to power up (almost like a whistling sound as it attempt to power up) then will power back down.
When was the last time you replaced the lamp? That sort of sounds like the ballast is unhappy with a bad lamp. The 57733 is a good TV. The other possibility is a stuck/dirty color wheel.
Check the lamp and see if it looks worn out(dark or grey in the tube down the center). Also make sure its either a Philips brand or Osram brand.
Let me know and Ill see what I can recommend next
Sep 12, 2016 | Mitsubishi WD-57733 57" HDTV
TV was working fine. Plays DVD's fine. Can't find HDMI from the cable, hence to TV reception. TV set works fine however on DVD's so it is not the set itself. Can't find the HDMI 1 hook up only the HDMI...
Tries tv and cable or satalite boxes unplug,replug it back for like about an hour later.By letting tv resetting itself back to the factory setting and those pay boxes upgrading it softwares.The tv HDMI signal for the tv incomming broadcasting signal should be back,if not, tv might have a dead HDMI cable or that the HDMI 1 hub it plug in is shorted and dead.
Feb 12, 2011 | Mitsubishi WD-57733 57" HDTV
How to remove and install tv lamp for model wd 57733
See page 62 of this manual. Read the section titled "Lamp cartridge replacement". It has detailed info with pictures.
http://www.retrevo.com/support/Mitsubishi-WD-57733-TVs-manual/id/3124bh436/t/2/
Feb 06, 2011 | Mitsubishi WD-57733 57" HDTV
How to connect my desktop computer to my mitsubishi hdtv?
If it has a PC input, no problem, just use a VGA cable. If not, don't waste your money on adapters to convert from PC to HDMI or Component. Picture is lousy and poorly focused. If your TV has a DVI input, That will work. frequency will match up. Hope this helps
Jan 09, 2011 | Mitsubishi WD-57733 57" HDTV
I need help connecting my wd-57733 mitsubishi to an optimus Audio video reciever. Right now I get a picture but no sound what do I have connected wrong to the reciever
Yes you did may sure the option for outside audio input is enable, go to tv menu screen and go to sound option and look for external audio and enable .
Dec 18, 2010 | Mitsubishi WD-57733 57" HDTV
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52631 shadows and blurs in dark lit movies
Good Day;
You may have a lamp going bad,when was the last time you replaced it? Or the DMD or light engine, try lamp first. Good Luck, big IRISH.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
