Question about Pentax Optio 50 Digital Camera
Lost a peice of copper from battery door.
I have a pentax optio 50 and it works great. The only problen is it won't turn on. A peice of the copper connection on the battery door got bent and fell off. Does anyone know where I could find parts or a parts camera?
    Problem Solver:
  • 13 Answers
EBAY and look for damaged or broken or even parts including the camera model.
Posted on Sep 25, 2008
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
Camera comes on. screen shows OPTIO AND AT BOTTOM V1.01 THATS ALL- none of the funtions work. camera won't shut offf. have to open battery cover to shut off.
If you can get into the menu system, find "reset" in the set-up menu. If not, remove the card and battery...press every button....leave it alone for 20 minutes...insert the card and then the battery...turn it on.....this is called a "hard reset" and sometimes works.
Jul 17, 2011 | Pentax Optio 50 Digital Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
W what size SD memory card can i use?can i use
You may use any SD card up to 2GB in size. Make sure you don't try larger SDHC cards, as they won't work.
Nov 17, 2010 | Pentax Optio 50 Digital Camera
IF MY PENTAX OPTIO A30 is turned on a blank screen
It sounds like you need a new main board. Pentax in Arizona will replace the main board for about $135, or I will replace it for $65. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Dec 23, 2009 | Pentax Optio A30 Digital Camera
My pentax camera keeps
I thyink there is a recommended brand for this camera and they should be Duracell.
Sep 02, 2009 | Pentax Optio 50 Digital Camera
Will not turn on. looks like it leaked water. power light on with no image in viewer.
i had a small amount of water inside, let ir sit for awhile, a day, with no battery or card and the door open, worked fine, used it again in water same problen, day just started, if it revives, no more pool.
Aug 13, 2009 | Pentax Optio W10 Digital Camera
Loss of button functionality
Try loading this Firmware update...
http://www.pentaximaging.com/customer_care/show_firmware?firmId=1020
I was having the same problems and my camera works great now after loading the update.
Jul 04, 2007 | Pentax Optio S4i Digital Camera
Pentax Optio 50 Digital Camera Logo
88 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
