Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Toshiba regza 52rv53ou
I tried every mode natural,theater wide,ect,and can't see updates at bottom of sreen,example watching espn can't see type also watching soccer or football can't see name of the team nane on top only bottom team
  • bforeman Oct 03, 2008
    Our Toshiba regza is also hooked up through HDMI cables to our digital cable box, and just recently we started having the same problem:  the margins of the image seemed to be cut off, as if the image were zoomed in slightly too much.  None of the picsizes seems to correct this.  The best setting seems to be Native, but nevertheless it crops off the outer edges.
  • rdh3t Nov 20, 2008
    yeah, me too. Worked perfectly for months, now the image is slightly shifted to the left and I get a thin green line along the right side of the screen when set to "native". I can make it go away with other settings, but at the expense of losing more of the picture off the edge of the frame.
5 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Regza 42"
ok...so do you want to work this out? the user manual speaks to this...
Posted on Jun 03, 2008
  • 905 Answers
SOURCE: Tv picture not all showing up
this is like the conversion Ic's that is for projection tv's, but different for an lcd or plasma tv , it will need to go to the shop where they can order the board to correct this problem. these boards are not available to the public. you can try to replace any components on the video processing board that are bad , like electrolitic caps , surface mount resistors , diodes , but if it is a surface mount chip then you will need the whole board , because thats the only way to get it
electech
Posted on Oct 25, 2008
SOURCE: cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Posted on Jan 20, 2009
SOURCE: More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Posted on Feb 05, 2010
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Green screen
Actually this seems to be an issue with your Video board.That's why you can adjust the color.
Jul 26, 2009 | Toshiba 57H81 57" Rear Projection...
50hz not supported on Regza 26HL47?
You should have no problem displaying a 60hz 720 format as that is what this TV is based upon or a maximum of a 1080i 60hz picture. The TV will not support a 1080p or anything trying to feed it a 24 fps picture such as a blue ray player set for that mode. If you connected a standard video signal to a component connection on the TV, yes it will work but as you saw it will be in black and white. With the correct component connector for the Wii I believe the maximum it can be set for is 480p (DVD quality) which is much better than 480i (standard TV). If the picture is stretched out too much check the TV setting by using the FORMAT button on the Toshiba remote to change aspect ratios IE: WIDE, ZOOM, STANDARD etc..The other settings you want to check is in the Wii control panel. It probably asks you the type of television you are connected to such as 4:3 or a 16:9. You will want to set it for 16:9 wide-screen and if the setting is there you want to set it for 480p or 720p if the Wiii has that capability.
Jun 15, 2009 | Toshiba REGZA 26HL47 TV
Cannot optimize picture width on new flat screen HD
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Regza 42"
Jun 03, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba 52" rear projection
   The theater wide feature 1 may not be available in all tv channel formats.
Try the downloadable manual at www.retrevo.com
Feb 23, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Compaq presario # SR1810NX model
Please try to uninstall the memory and fixed back then start the computer.
i same problems; Back up your important files and then provide windowsxp bootable disk and boot to cd/DVD rom and install the new windows.
Jan 04, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
265 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
