Apple iPod nano Logo
Posted on Sep 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DELETING HOW DO YOU DELETE SONGS OFF THE IPODS AND ADD SONGS I JUST GOT IT AND DONT KNOW ANYTHING ABOUT IT I BOUGHT IT USED WITH NO MANUEL IF YOU COULD PLEASE HELP ALSO WHERE DO YOU GO TO DOWN LOAD SONGS THANKS DEBBIE
Anonymous
Level 2:
  • Apple Expert 108 Answers
  • Posted on Sep 26, 2008
Anonymous
Apple Expert
Level 2:
Answers
108
Questions
0
Helped
140894
Points
144
My mp3 player has a lock pictured on it.. it wont play i cant add or delete files because of the picture of this lock. i dont know how this lock ended up on here
Try deleting the songs this way
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Please rate me
Need help deleting songs from ipod and loading more on it?
Connect your Ipod and the device will be detected onthe PC. you can select and delete off all the files that is opened after checking them one by one.
Now Apple nano needs the use of the software ITUNES that is available in the apple ipods nano site. Log on and download , install and run the program.
You can now select all the songs to this software which can be loaded into the nano ipod on connection and routing.
Dont forget to vote .
Deleting songs off mp3. Mp3 is full so i want to add more songs. So I need 2 delete so or all of my songs off my mp3. & i'm 14 so it gets boring havin 2 listen 2 the same songs that you don't even want...
try using windows media player to navigate thru the file on you mp3 player and delete the ones you dont like on it then use the media player again to sync the new ones onto it
Adding and deleting songs from my ipod nano 4th generation
2 guides that would help you :-
http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/what-is-ipod-how-to-turn-off-delete-photos.html
http://ipod.about.com/od/addinganddeletingsongs/Adding_and_Deleting_Songs_from_your_iPod.htm
Thanks.
2answers
I can't delete songs off my YP-T9J
It's not a hard work that you can have a try powerful program Leawo Tunes Cleaner. Leawo Tunes Cleaner is a professional duplicate music remover.
Step 1. Run Tunes Cleaner and Scan Duplicate Songs
After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
Step 2. Add Music Files for Duplicates Removing
You could delete duplicate songs in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing. Or you could directly drag music files from your local folder to the software for duplicates removing.
Step 3. Start Deleting Duplicates
After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
tunes-cleaner-scan-result-gwujvob1wsqcwi5j4bnkubbk-3-0_0.jpg For more details, check: How to Delete Duplicate Songs
How do i delete songs that i dont want without deleting all the songs
how do i delete songs that i dont want without deleting all the songs
Cant delete songs or format da player
I bought scan disk mp3 but once i have connected it with my laptop to add new songs , i dont know what happen now it is blank all data is lost i can now only listen radio through it songs are not adding into it. as all dta is lost or formated.
Songs
to add or delete songs you simply view it as a hard drive then drag and drop the sings you want on the folder marked sansa.  to delete do the same thing in reverse.
2answers
Deleting songs???
You can delete the songs thru the PC.
My Computer>Device Name (m230)>Music Folder.
Just right click and select DELETE on the songs you dont want.
Best of Luck.
Please RATE my solution BELOW.
2answers
Deleting all memory at once
Ipod manuals http://www.apple.com/support/manuals/ipod/ Not sure if you have 1st or 2nd gen 1st: http://manuals.info.apple.com/en/iPod_nano_Features_Guide.pdf 2nd: http://manuals.info.apple.com/en/iPod_nano_2nd_Gen_Features_Guide.pdf These manuals suggest that when you connect to itunes, it automatically deletes all songs not in your library. Otherwise i don't see a format option unless the drive shows up in my computer and you can format it there (right click). It basically suggests that you have to use one of the manual methods on the pod or computer to delete songs. Have fun!
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
