Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black and decker corded lawnmower barely runs
I plug it in and it barley runs,tip it over on side runs fast what is wrong? Grass height has no effect.
  • OMANANA8 Sep 28, 2008
    I went back and looked again,found one of the blades on the fan is broken,I ordered a new blade.Anyone know how to remove the old one,on a black and decker corded mulching mower?
    Scholar:
  • 121 Answers
It sounds like you have a loose connection somewhere in the motor
Posted on Sep 27, 2008
My electric lawn mower power keeps cutting out IT RUNS WHEN PLUGGED IN BUT VERY SLOW,TIPPED OVER RUNS FAST.bLACK AND DECKER CORDED 19 INCH REARBAG
if it runs slow when mowing then when its tipped upside down there is no pressure on the blades its faster the bearing is gone worn out
Sep 25, 2008 | Black & Decker 19" Electric Lawnhog...
Not cutting
If the mower starts and runs, then shut it off.
Find the spark plug.
Now, tip the machine up on its side WITH THE SPARK PLUG UP.
(If you do not, and if you tip it the wrong way, you can fill the combustion chamber with oil and ruin the machine when you try to start it again.)
Once it is tipped, look under the machine, and feel the blade to see if it is tight or loose on the motor shaft, and also if it needs to be sharpened.
If loose, tighten it.
If dull, sharpen it.
God bless your efforts.
Apr 12, 2016 | Garden
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
I own a cordless Black & Decker 19" rechargeable mulching mower, CMM 1200, 24V. There are days that it starts beautifully, and others where it remains quiet and uncooperative. Temperature seems to...
Mulching mowers are notorious for needing to be cleaned out frequently. The problem usually is the cutting height. The lower it is, the faster it gets clogged up.
Cutting wet grass doesn't help this situation either, it actually makes it clog up much faster.
Set the cutting height to about 3", and wait until the grass is dry before you cut it. This should help with the cuttings buildup.
As a landscaper, I deal with lawnmowers on almost a daily basis, and on cold mornings, the mowers are sluggish and don't want to run well.
If you keep your mower stored in a weather proof building with a consistent temperature and humidity level, there shouldn't be many issues with startup. Start it up and let it idle at half choke before cutting.
I hope this helps you.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Jul 31, 2011 | Black & Decker Cmm1200 24v 19" Cordless...
I have a black and decker 18 in lawn-mower. I bought a haeavy duty extension cord to connect power to the lawn mover. It was working then suddenly it stop and blew the switch. I plug the cord to a...
I would say the outlet/ cord. here is a recommended types and lengths of extension cord, Tim:
http://support.mtdproducts.com/app/answers/detail/a_id/435/~/what-type-%26-size-of-extension-cord-can-be-used-with-an-electric-mower%3F
May 29, 2011 | Black & Decker Black and Decker & Grass...
Black&Decker MM675 lawn mower height lever would not stay
I would look in my owners manual and get the part number for the height lever and order a new one. You could also try and wire the height lever so it can not move. I am not sure how it engages but you could may be try and bend the lever so it is tight and won't move. Just a couple of ideas.
Good luck
Aug 31, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
163 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
