SOURCE: subzero 690 flashing EC and service
EC means extended run time. Find a subzero authorized servicer and he will probably need to replace the refrig section evaporator assembly.
SOURCE: Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Rhino, this is yet another simple fix. You need to call subzero and let them know that your ref section is not cooling properly. 9 out of 10 times it will be a problem with the evaporator coil needing replacement. Sub is aware of this issue and usually picks up the tab for this repair.
SOURCE: fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
SOURCE: My subzero 650 is flashing EC 24?
better call a tech. ec 24= check for proper ohm reading of defrost heater. replace heater if defective. or check the the thermistor(location) and remount correctly
