Question about Electrical Supplies
Coleman powermate pm0545305 10hp brigg & stratton
Hi , can you give me a hand again please..
sorry for my bad english..
Ok , i can't start it , seems like there is no fire and after i tried it a couple of time there is too much gaz in the carb.. i wrote you about oil in the carb but i did a mistake it was gaz... i don't really know how to check if there is a spark.. i took the spark plug out (no damage on it , no gaz on it), put the wire on , tried to start but haven't seen spark . The thing it that 1 week ago everything was going well then i change the oil and i realize that there where no dip stick at all on both side .. i don't have the manual and i know that it will stop running if oil is too low.. i filled with oil about 2cm under the tread of the oil plug .. air filter is clean.. i really don't know what happened !!! i just change the oil and nothing works anymore.. Please if you can , give me a hand for the second time ! i'll apreciate it a lot.
  • karmina Sep 25, 2008
    haha i know what it feel like to put your finger on a spark plug.. tought there was a better idea !! Alright i'll remove the carb to clean it up this week end. i'll let you know if it finaly start ! thanks and have a nice day!
    Problem Solver:
  • 13 Answers
Go ahead and feel the oil resevior full . it will not hurt it. if you really want to find out if it is firing. if you are tough enough, put your finger on the spark plug and barely pull pull cord. you will definitely know if you are getting fire. it does kinda hurt though.....ouch!
if it is getting fire, then make sure gas is good. you may have to remove the carb bowl. the carb float may be sticking and the float pin. if this is the case, you may want to spray them with carb cleaner. if you know how to remove the carburator. you could soak the whole carb in carb cleaner. let me know how this works.
Posted on Sep 25, 2008
  • tb2830 Sep 25, 2008
    also the reason to cean carb is it may be getting too much gas. make sure you take it off choke once it starts.
Oil to used for a briggs and stratton genpower 305 10hp ohv engine
Hi Jim, sae 30 mineral oil for all Briggs engines. Regards Phil.
Sep 24, 2011 | Coleman Powermate Powermate 5000W...
PM052520 Coleman Powermate run and cur off
If it is a Briggs & Stratton engine it most likley has a fuel pump
Aug 31, 2011 | Coleman Powermate Powermate 5000W...
Briggs and Stratton GenPower 11 generator cover plate ???
I have a Briggs & Stratton GENPOWER 11 generator that is electric start. The electric start will not start the motor or ever turn it over. I can turn the key on and jump across the terminals on the starter and it will run only if I continue to squirt starter fluid in the carb. My question is, if the ignition switch is bad, could that be the reason it will not stay running. My only guess is if the ignition switch is bad, the motor thinks it is in the off position at all times. Thanks, R Ray
Jul 16, 2010 | Coleman Powermate Premium Plus 6250W...
Where do i get a coil at?
Well, if Briggs and Stratton engine, then try briggs and stratton.
If Robin / Subaru engine, try there.
Write down the model type and serial numbers, then pay a visit to local small engine repair shop and have them order for you.
Dec 21, 2009 | Coleman Powermate Powermate 5000W...
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate PM0545305
you can check the oil on both sides. one side should have a dipstick. normally just fill it up all the way. you say oil is in the carb. spray some starter fluid in carb. and make sure air filter is clean. try to crank it and see if it will start. let me know if this took care of problem
Sep 21, 2008 | Electrical Supplies
Electrical Supplies Logo
268 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
