Question about Maytag Refrigerators
My daughter has a Bottom Freezer Maytag fridge. Model# PBF2253HEW , Serial # 11366421GR. She has had the refrigerator replaced ounce while under the 1 year warranty due to defrost problems that were not resolvable seems this Model # fridge has gang plugs and wireing harness problems from what i understand. She is now having problems again with the same problem.I checked defrost heater it is good and the defrost thermostat it checks out good. So i replaced the circuit board assuming that it was not cycling into the defrost mode. The diagnoses was wrong, i have rechecked the defrost system again, heater is good, defrost t-stat is good. I had run my own appliance repair for 20 years have been out for 10 years so iam not familiar with the circuit board that controls the defrost cycle. Can you tell me how to trigger a defrost cycle with this circuit board? This is not as simple as advancing a defrost timer into defrost. I suspect that one of the gang plugs in the wireing harness has a poor or loose connection but am unable to locate it. Since this seem s to be common for this fridge can you give me any info on where these failures are occuring with this model of fridge? Thanks Jim.
  • Anonymous Feb 22, 2009
    how do you manually defrost a bottom freezer maytag
    President:
  • 1,462 Answers
Cannot usually be done to trigger defrost. best you can do is to try to trace which edge connector goes to heater and with everything disconnected, apply mains to the edge connector
Posted on Sep 25, 2008
How do I clean the coils on my Maytag freezer-on-bottom fridge? (Model #i is MF D 2560HEW)
HI,
Pick up a coil brush from you home improvement center near you and remove the grill in the front under the freezer door. With the brush, brush the coils under the unit to clean them. Have a vacuum handy, you will need it for dust and hair if you have pets in the home. Good Luck
Apr 20, 2016 | Maytag Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Maytag side by side door slamming shut
what's the model number and what's happening with it,do you mean the fridge is on top and freezer on bottom?open the fridge door,look up on right hand side up near ceiling and send the model number and the first two numbers of the serial number
Jun 18, 2012 | Maytag Refrigerators
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag PBF2253HEW; freezer fan not working and fridge not getting any cold air. Ice maker only dropping about every 6 - 8 hrs. What needs to be replaced? (This was a friend's refrigerator, he used for 2...
Mark Remove the rear panel in freezer. Apply 3n1 oil to fan motor shaft and plug in and spin. I believe they left the freezer shut and the moisture froze the shaft on fan with rust. Once restarted you will be fine. Sea Breeze
Jan 27, 2010 | Refrigerators
Cooling shut down
It is,Check with Maytag to make sure it isn't still under warranty, some had five years on the sealed system,it would also be in your owners manual.
Sep 01, 2009 | Refrigerators
Maytag PBF2253HEW temp control lights blinking
Your heading has two model #'s if your dealing with a PBF2253HEW you need a new jazz board pn W10165748 this part also controls your automatic defrost cycles if lights are flickering you should replace prior to something else going wrong
Apr 02, 2009 | Amana ARS2464B Side by Side Refrigerator
Older model bottom freezer PBF2253HEW: buzzing starting/stopping
You'll have to listen to the noise to see if it is coming from the compressor but it sounds as if the start relay on the compressor is going bad, you can use a 3in1 start kit to fix this contact us at www.airenergyexperts.net
Mar 14, 2009 | Refrigerators
MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Oct 02, 2008 | Maytag Refrigerators
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Refrigerators Logo
186 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
