Fatal error msi.netdevicemanager01 - Office Equipment & Supplies
  • 2 more comments
  • Philipp Jean-Jacques Nov 11, 2008
    Uninstalled HP Printer, now an Fatal Error pops up during the installation, while trying to connect to the Printer. I have C7250 Photosmart Printer. the Error Says: Invalid Drive X:\ , while X is the Drive letter of the FAT32 portable Harddisk I had connected during the first install but not during the uninstalllation. The error still pops up after manually removing all registy entries that were created by the installer.
  • HansJant Dec 27, 2008
    The same problem on HP AiO Photosmart 7200 on Windows XP Pro. The installer software says it found newer network drivers and returns with fatal error. Uninstalling the former network printer (HP CP1510) again with McAfee off does not solve the problem. The network software is not uninstalled at all - only the HP print/scan drivers. So, please has someone a solution for it.
    Thanks.
  • Anonymous Dec 28, 2008
    mike
  • monicawang Apr 25, 2009
    I just purchased a All in One HP Photosmart Premium 3C09. When I was installing the software on my laptop (windows xp) it always pops up with "msi.netdevicemanager01". It says "Fatal Error during installationg...Module C:\Program Files\HP\Digital Imaging\bin\HPSLPSVC32.DLL failed to register. HRESULT-2147467259"...
    I have tried to reinstall a million times but it doesnt work. It usually pops up during 17% of installation.
    Sniper:
  • 66 Answers
1)Stop the installation
2)Go to Command prompt
3)then type : subst X: C:\
4)Press enter
5)exit out of command prompt
6)Then restart the installation again it should complete
X:\ is the drive you are getting at the time of the installation as invalid drive.
Posted on Oct 05, 2009
  • rsteinbac452 Aug 02, 2011
    Thank you.
    Thank you.
    Thank you.
    I spent a whole afternoon trying exotic fixes, and this simple instruction worked!
Well the solution to this problem is quite simple. This error does only pop up for Vista Users that do connect a portable device and set their Home Folder (e.g. normally C:/Users/Username/Pictures and change that to X:/Pictues, where X is the drive letter of the portable drive). This change results in invalid registy entries when you disconnect the portable device and so everytime you want to install something, the microsoft installer (msi) pops up this message.
But thanks to biigg53566, the other problem i had (this Service is not installed, during device search) was kinda solved.
Posted on Nov 18, 2008
  • 28 Answers
Perhaps this thread about invalid drive link will help:
http://www.out-of-warranty.com/invalid-drive-when-installing-hp/
Posted on Mar 08, 2010
  • 81 Answers
Keep trying to uninstall the printer software, the key to this problem for one I found out is make sure if you have firewall leave that on, but any anti virus off- and any other programs you may have running have to be closed. I have a HP-C6280 photosmart all-in-one printer, once I got the uninstall done.
Restart your computer that is a must then again turn off your antivirus, then try to reload the software, just follow the on screen instructions and you should be on your way.
Just plug in your external device and connect it to the system. Then run the software and it will not give you the Fatal Error message, and should completely install the drivers, and allow connection to the printer wirelessly.
Posted on Oct 09, 2010
3 Suggested Answers
  • 49 Answers
SOURCE: I'm getting fatal error "MSI.netdevicemanager01"
step 1>
remove netdevicemanager.msi from windows cleanup utility.
then try to install software again.
step 2>
remove netdevice manager from registry.
hklm > software > hewlett packard under hewlett packard you will find many {4dfg324.........} entries on left. if you will check each one of these code entries has its discription on right hand side of registry window. each one of these are for scan.msi, solution center.msi.... etc. fine out netdevicemanager.msi adn uninstall that {code} key from hewlett packard. these code keys may also be found in same location under hewlett packard under install key or installed options.
Posted on Dec 15, 2009
Avg installation fatal error 0XC0070643 fATAL ERROR URING INSTALLATION MSI engine: failed to install the product
0XC0070643
Oct 19, 2010 | Computers & Internet
Can't download iTunes, IE 8, HP Printer...Fatal Error MSI Scan is the usual statement, although I've gotten numbered failures too. But Fatal Error is the main one.
Hey
The SCAN.MSI that comes up about your HP printer, that is located on the CD in a special folder.
It would be best for you to completely uninstall all HP programs from the computer related to the printer.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
unplug the printer first
use the free(ware) version. Download the program, start it, go to the uninstall programs part, find the HP related items and uninstall, Use medium setting and delete all files and items it finds, just click on select all and then delete.
When that is done restart the computer, then use the CD or I'll direct you to the full feature download to reinstall it.
I've delt with this scan.msi issue quite a few times here and I know how to solve it. If this doesn't work for whatever reason you would have to go to the cd (right click, open) and find the scan.msi file, when the error comes up asking for the scan file, direct it there (Exactly to the file in the cd, it may be hidden inside a few folders) and it should solve that one.
May 08, 2010 | Computers & Internet
I'm getting fatal error "MSI.netdevicemanager01" when installing the software for my new HP C309a.
step 1>
step 2>
Sep 03, 2009 | Xante Accel-a-Writer 4N Laser Printer
I get fatal errors MSI.aio.scan when installing HP
try uninstalling ie8 if you have it installed hp software does not like ie8
Jun 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
Dear Esperts, I want to install HP C7280 on my XP Pro. The pop up message appeared as follow: "Fatal error during installation Invalid Drive: E: Fatal Error MSI.netdevicemanager01 " Any suggestion to solve...
Sounds like a problem with the installation disk.
Try clicking on this link the download the Full feature software and drivers package
Allow it to install. If it works your done, if not the disc isn't the problem. If that is the case respond back here with any error messages that show up and I will take a little deaper look into the problem
Hope this helps Fixya,
Chris
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3204785&lang=en
May 03, 2009 | HP Photosmart C7280 Laser Printer
MSI.dot4wrp01
Fatal Error during Installation - MSI.dot4wrp01
Try this link. I was able to resolve this with this solution.
Mar 25, 2009 | HP Photosmart C4280 All-in-One InkJet...
Windows vista installer msi errors and fatal error
it cood be the wrong type of photo paper try some other type
I HOPE THIS HELP
SHORTY
Jan 08, 2009 | HP OfficeJet 6310 All-in-One Printer...
15,489 people viewed this question
jasbo
jasbo
