Question about Mitsubishi WT-46809 46" Rear Projection Television
Sparks coming from FBT
I downloaded a manual and we have sparks coming from the FBT. Not even sure what FBT stands for. Can this be fixed? If so, can we do it and where to get the part, or do we need to take it to a repair shop. Don't want a huge repair bill - when a new TV is about the same.
  • bessfam Sep 25, 2008
    I have a meter somewhere but haven't found it yet. We have been working on the house and things get out of place. The only thing we found was an outlet voltage tester. Could this repair get expensive? If so maybe we should just put the money into a new TV. Any thoughts?
  • 203 Answers
If the sparks are coming from the flyback transformer then it needs to be replaced. You would need to be able to use a meter to determine if more damage has been done or not. Let me know If you can use a meter and i will give you some stuff to check. If you take this to a repair shop you can bet on $400-$600 for repair.
Tim Nolan
Posted on Sep 25, 2008
Possible failure of the motor and so it must be shut down before it can become dangerous. If the sparks are seen to come from the inside of the motor it can be due to even water logging or a failed winding. Confirm and replace.
Jan 12, 2013 | Washing Machines
Yamaha XS 650 bike has spark after the start button is released
Hi, Anonymous the answer to this question is way above my pay grade and for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
No spark when cranking sparks when start button released
TRX450ES sparks only when you let off starter
Yamaha XS650SE Shop Manual
OEM parts for Yamaha
Yamaha XS1 650 Owner Manual
Feb 14, 2012 | Yamaha XS 650 B Motorcycles
What part do i need to replace to fix a buzzing noise on a Sanyo DS25390? Thanks, Jason
This tv problems,have 2 possibilities problems.1 the CRT(Tv tube) itself is dead.This u can hear the CRT Video board connection buzzing noises at the CRT-(Tv tube) head.The CRT is dead,also have a little high volt sparks flashing on the video board components too.2 is the FBT-the Flyback Tranformer is dead.This is a highvoltage transformer,a big black block of plastic with a red wire with a cap hook to the CRT(Tv tube).This will make buzzing sound at the base of the FBT.If it is the FBT-it is repairable,if u still can find the FBT part for ur tv model.This part the FBT is a critical part for the analog tv to work.Require tools and also know basic soldering too a must.
Dec 01, 2010 | Sanyo DS25390 TV
Sparks coming from inside of oven
This is a simple fix.
You need to remove the rack and all of the holders.
Clean the metal thoroughly where the rack mounts fit.
Replace all the rack mounts with new ones, insert the rack and you're all set.
Then be sure to keep it really clean, even if you have to remove the rack and new mounts periodically to get it really clean.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Dec 27, 2009 | GE Profile Spacemaker Over-the-Range...
My tv will not come on and sparks when i plug it in
If it sparks when plugged in that means the main fuse in the tv is not blown. If there was sorting wrong with the tv and you saw sparks the fuse should blow. If the fuse blew you will not see sparks anymore and the set will not come on. But if the fuse did not blow one of the following can be the cause.
1. A short in the line cord, check you plug and wire to make sure there are no breaks in the wire.
2. Sparking can be from a bad outlet, a plug that is not making good connection can cause sparking, try plugging in to another outlet if it still sparks check the prongs and make sure they are not blackened.
Oct 05, 2009 | RCA P52937 52" Rear Projection Television
Engine shakes after changing sparks plugs & wires on 02ChevyTahoe
could be a bad plug even know they are new one might be bad , first check in the dark for any arcing (blue sparks) coming from wires might be a split in one of the spark boots ,make sure on there good,also a chance you put wire to wrong cylinder
Oct 01, 2009 | 2002 Chevrolet Tahoe
Sparks when shooting a nail
It is common to see sparks. It is metal striking metal. Although, if it sparks alot. It could be a chipped driver blade and the nail would not drive all the way. Does your sink `em?
Aug 15, 2009 | Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15...
Won't stay running. when i move the the neg cable the electric comes to life but the cable sparks
Small spark when connecting is normal...large sparks indicate a short. clean the terminal to make sure there is solid connection where sparks are.
Aug 02, 2009 | Ford Bronco Cars & Trucks
Fly back is arching and leaking
hi, i'm having a similar problem and was wondering if you ever got yours fixed? i've found the FBT, it's located on the bottom right side as you're facing the back of the TV and it has 3 red wires coming out the top. mine, i've noticed, sparks once when the tv is turned on. i can't find a replacement part for under $300. any suggestions?
Feb 26, 2009 | Philips 55PP9363 55" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
