Question about Refrigerators
Fuse bob, was that a slow burning fuse or fast burning?
I used a slow blow fuse. The blown one looked like it was a slow blow - there was quite a bit of material in it - but it was hard to tell because it was blown.
Posted on Sep 26, 2008
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
Pioneer 74txvi fuses (fast or slow) burning
If there is nothing left inside the little glass tube, it's a fast blow. A slow blow fuse will usually have a spring and some other material that make up the slow blow mechanism. slow blow fuses used to also have 'SB' stamped on the metal end caps. The fuse holder may also tell you. If you cant figure it out, put in a fast blow and see how long it lasts, If if blows when you turn the volume high, you should try a slow blow.
Jan 22, 2015 | Pioneer Audio Players & Recorders
Toshiba 37E200U LCD television
T5.0AH 250V used in this TV is a ceramic fuse Time delayed (Slow-Blow) and the dimensions are probably: 5 mm (3/16 in) x 20 mm (3/4 in). You just measure the old one.
Regards GJ
Jun 20, 2014 | Toshiba 37E200U 37 in TV
Samsung fp-t5084 fuse fix is the replacement fuse slow burn or fast burn?
I'm certain it uses a T12amp slow blow type. I have the exact same model, you can replace the fuse. The TV will for a while, but that fuse will blow again. You will need to replace the power supply board for a more permanent fix.
Dec 21, 2012 | Samsung FPT5084 50 in. Plasma HDTV
Polaris grandfather clock runs slow need to adjust time up
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Nov 17, 2012 | Watches
How much damadge is done if radio is pluged in wrong. in line fuss blew but radio wont work with a new fuse
To check the damage you need a ohm meter,take off the cover and look for D23 I think, check the resistors and capacitors around this for burned,puffy,etc.Also check the circuit board for burn trace.Replace with same or sub parts. ..hope this helps..
Mar 21, 2010 | Cobra 29 LTD CB Radio
I need to replace the external fuse on a marantz Model 32 amp.
Well, take good look at the Fuse itself on metal area.
If it says AGC, then fast acting.
If it says MDL, then Slow Acting.
If you cannot figure it out, then just use Fast Acting since it is more commonly used in smaller Receivers and Amplifiers and Fast Acting will cutoff faster (compair to Slow Acting) if there is any unknown Prblem with Chassis.
Jan 31, 2009 | Audio Players & Recorders
Fuse blown
Hi mate most uk set have a 3,15amp 250v fuse ti dosent matter if its quick or slow all the best Bob
Aug 13, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
