Samsung SyncMaster 245BW Monitor Logo
frank guidi Posted on Oct 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung 17 inch monitor has power cord problem. Keeps going off. Useing with my wisecomm 8 ch security system.
danielle yancer
Level 2:
Habit-Forming:
  • Expert 107 Answers
  • Posted on Oct 31, 2011
danielle yancer
Expert
Level 2:
Habit-Forming:
Answers
107
Questions
Helped
24390
Points
293
Its probably not the cord its the monitor its self its over heating and your gonna go to turn it on and it wont come on. But the light with light up at that point you have a swollen capacitor and would have to take it apart and replace it which most people are not savy enough to do. Throw it away get another
How to check Samsung 732N 17 inch Monitor Power supply module
Open the case, open the main power supply board out and check the dc volts on the pins of the connector to the VGA board the volts are written in the board
Monitor SAMSUNG 961BF does not turn on no picture?
  1. Verify that the power cord and Monitor cable are securely connected and not damaged. Unplug and replug these cords back in and test functionality.
  2. If the monitor still ceases to function, you may have a bad board, lcd screen, or inverter.
  3. I recommend replacing the monitor unless you are familiar with testing and replacing electronic boards and LCD screens.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Hi, my BenQ FP72G 17 inch LCD Monitor keeps auto-adjusting every 5 seconds and every now and then it will turn itself off and later go on again. Any help ?
Make sure the cables are in well with a good amount of slack, it can cause a problem if your power cable or computer to monitor cable is loose
Where does it go? what does it look like.
heres the proview site http://www.proview.com/Product/Product_Sub-category.aspx?ii=212
I suspect it uses a kettle type plug - that looks like this https://www.cashgenerator.co.uk/_images/product-details/BE991.jpg and the connector looks like this http://acimg.auctivacommerce.com/imgdata/0/1/2/8/8/9/webimg/1310841_t.jpg See what you have on the back of the monitor - if it does look like that connector - those cables are avaibable at most store - what country are you in ?
Monitor keeps going off and on. All cords seem
ALL LCD monitors have a thermal protection circuit that turns the monitor off when it is overheated. LCD monitors do not have air circulating fans, so dust buildup is a problem. If your monitor is still under warranty, Please contact your retailer or Samsung at samsung.com/support. If it is out of warranty, you can try to repair it youtself. The steps to follow are:
1. Fold a large bath towel in half and put it on a table.
2. Disconnect the monitor from everything.
3. Remove all cables from the monitor
4. Place the monitor face down on the towel.
5. Remove the four VESA mounting screws that hold the desk mount to the rear of the monitor.
6. Remove ALL of the Phillips head screws from the rear of the monitor.
7. Use a thin bladed tool to release all of the plastic catches that secure the rear cover to the front cover of the monitor.
8. Use a small brush and a hose type vacuum cleaner to remove all of the accumulated dust from the chassis.
9. Put everything back together by reversing steps 7-2.
power it up and see if this corrects the problem.
10. Do not block any ventilation holes in the case.
3answers
Need a power cord I think my wife tossed it???
You can buy a regular power cord at the store such as wal-mart, staples, bestbuys. Most monitors have a standard power cable, similar to that of the computers.
Samsung SyncMaster 710N 17 in. Flat
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Monitor with horizontal shakes
i have found a twisted groundline makes my monitors horizon dance, try a more natural approach to your power cord setup, like a waterfall or growing vines, rigged every 8 inches
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
