Question about Kitchen Ranges
Stove Hi, You have been trying to help us with the stove. It is greatly appreciated. Still no luck though. It was set up correctly as it had been used for a while before it went into this cycle.
  • 706 Answers
Hi ,
Let me think about this some more and see if there are any other things that can be tried to solve this dilemma. There must be something I am overlooking.. Will continue to assess things.. hang in there...
Posted on Sep 25, 2008
Burned out Napolean stove.
Hi i would write to the company first asking about this problem see what they come back with bypass the rep go higher
Feb 12, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
Digital clock will not stay on.
Hi
I hate to tell you but the timer is failing.
If you can give me any model and serial numbers i will find a replacement price for you.
regards
aardvark Repairs
aardvark.repairs@btinternet.com
Nov 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
Jun 11, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Electric range burners and oven element just stopped working. Burner indicator light came on and oven temp setting displays correctly. Clock went into set mode automatically, though. Burner came back on...
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Dec 10, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Westinghouse stove
Turned the self cleaner on my electric stove although oven door at end of cleaning cycle would not open, it remained locked.
Would greatly appreciate any ideas.
Thanks
May 15, 2008 | Westinghouse Bethany Antique Brass- Indoor...
Frigidaire deluxe electric stove Model# RDG3-35S
The pipe is a vent pipe it is normal and th fuse is behind the back panel right behind the pots and pan shelf beside the stove pull the shelf out and replace the fuse with a 15 amp
Jan 01, 2008 | Kitchen Ranges
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
