Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
FRIDGIDAIRE MODEL FRS26LH5DSR NOT COOLING REPLACED CONTROL MODULE
FOUND CONTROL MODULE BURNT REPLACED ALSO EVAP FAN BURNT WAITING FOR NEW ONE.ARE THERE ANY OTHER ELECTONIC COMPONENTS THAT MIGHT NEED REPLACING
  • 943 Answers
Hi. thanks for the question .there is a part that could cause a no defrost problem, in the freezer. its the defrost termination switch. when replacing the fan motor. replace it as well .cheap part, save problems later. thanks the appliance doc
Posted on Oct 01, 2008
Engine fan stays running all day . it just started ,
What make , model and year vehicle ? You mean cooling fan's for the radiator . Some makers use a module to control the cooling fans others use relays . Looking at a wiring diagrams would show control componets . Relay contacts could be stuck sending constant B+ voltage , keeping fans on , same with a control module .
Jan 24, 2017 | Cars & Trucks
Has 4 bulb capacity and for a long time only 2 of the 4 would work. The other two would blow out. Last week the replacement bulbs blew out as soon as we flipped the swith then there was a burn smell. ...
WAIT! Are you SURE the 98480-02 is burnt? This is part of the FAN circuits and NOT your lights?
But wait again! Here is ANOTHER Link complaining about LIGHTS and this FAN module (who knew!):
98480X Hunter Fan Control Switch Repair
(I know, their photo does NOT match your part)
IF it is burnt here is a replacement for under $9
https://www.lightingdirect.com/craftmade-4565uf-ceiling-fan-triple-capacitor/p3035848?uid=3035848
It's proper name is: "Hunter Fan model 98480X control switch".
Anthony
Sep 22, 2017 | Hunter Ceiling Fan Light Switch Control
Cooling fan wiring
the cooling fan itself maybe your problem, high resistance due to the motor being internally shorted but not totally gone, sounds like it my let you down shortly, I'd replace the cooling fan motor and burnt connector.
May 31, 2013 | 1999 Ford Escort
Car is overheating ...already replaced waterpump, flushed radiator, changed thermastat and replaced new water cap. there is no leak, and it over heats sometimes not everytime?
Hi!!
Make sure the small hose going from the reservoir to the radiator and the orifice at the reservoir are not clogged. If OK, check electric cooling fan system, specifically the Coolant Temp. sensor, Fan Relays and Constant Control Relay Module (CCRM).
Electric cooling fan system consists of a fan and electric motor attached to the fan shroud.
  • Engine temperature is monitored by the Engine Coolant Temperature (ECT) sensor.
  • Fan is controlled by Constant Control Relay Module (CCRM) with inputs from Powertrain Control Module (PCM).
The electric cooling fan is wired to operate only when ignition switch is in ON position and engine temperature exceeds specified temperature, or when A/C is on and vehicle speed is less than 45 MPH. During hard acceleration, the Wide Open Throttle A/C Cut-Off (WAC) relay controls the A/C clutch and cooling fan. A signal is sent to PCM and then to the CCRM, where the module de-energizes the A/C clutch and cooling fan, decreasing engine load during acceleration.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 16, 2011 | 1996 Lincoln Continental
2004 niisan infinty g35x code p2135
NISSAN OBDII DTC
P1105 Manifold Absolute Pressure/Barometric Pressure Switch Solenoid Circuit
P1110 Intake Valve Timing Control Circuit (Bank 1)
P1120 Secondary Throttle Position Sensor Circuit
P1125 Tandem Throttle Position Sensor Circuit
P1132 Intake Valve Timing Control Position Sensor (Bank 1)
P1135 Intake Valve Timing Control Circuit (Bank 2)
P1137 Intake Valve Timing Control Position Sensor (Bank 2)
P1140 Intake Valve Timing Control Position Sensor (Bank 1)
P1145 Intake Valve Timing Control Position Sensor (Bank 2)
P1148 Closed Loop Fault Detected (Bank 1)
P1168 Closed Loop Fault Detected (Bank 2)
P1210 Traction Control System Signal Fault
P1220 Fuel Pump Control Module Fault
P1320 Ignition Control Signal Fault
P1335 Crankshaft Position Sensor Circuit
P1336 Crankshaft Position Sensor circuit
P1400 EGR/EVAP Control Solenoid Circuit
P1401 EGR Temperature Sensor Circuit
P1402 EGR System Fault Detected
P1440 EVAP Canister System Leak Detected
P1441 EVAP Vacuum Cut Valve Bypass Valve Circuit
P1443 EVAP Canister Control Vacuum Switch Circuit
P1444 EVAP Canister Purge Volume Control Valve Circuit
P1445 EVAP Purge Volume Control Valve
P1446 EVAP Canister Vent Valve Circuit
P1447 EVAP Canister Purge Flow/Volume Control Valve Circuit
P1448 EVAP Vent Control Valve Circuit
P1490 EVAP Vent Control Valve/Bypass Valve Circuit
P1491 EVAP Vacuum Cut Valve/Bypass Valve Circuit
P1492 EVAP Canister Purge Control Valve/Solenoid Valve
P1605 Transmission Control Module A/T Diagnosis Communication Line Fault
P1705 Throttle Position Switch Circuit
P1706 Park Neutral Position Switch Circuit
P1760 Overrun Clutch Solenoid Valve Circuit
P1900 Cooling Fan Control Circuit
sorry but your code reader is not reading manufacturers codes ,if an american market vehicle then you should be able to read them but if this is a europeon model then how did you manage to get this code??
P0235....Turbo/Super Charger Boost Sensor 'A' Circuit
this is a generic code if its any help
Nov 02, 2010 | 2004 Infiniti G35 Sport Coupe
The car runs hot and the fan isnt starting
U may have a defective engine cooling fan control module, it is located behind and below the left front headlight bucket, u must remove the headlght assembly to access it, it is a very common problem, if u find the wiring burnt at the controller or the fan or both repair all the burnt wiring and replace the fan control module and the cooling fan,
Jun 12, 2010 | 1999 Jeep Grand Cherokee
No cooling or compressor operation
Compressor and evap fan cycling are controlled by a circuit board as well as the defrost. It is all in serie - once your defrost kicks in contact is cut from the evap fan and compressor - once defrost is finished the switch reverts back to normal operation and your evap fan & compressor turns on.
Most common causes of this issue is either a defrost timer fault or control board (burnt resistor or bad board).
Inspecting and changing the control board will usually fix the issue - if your evap fan comes on after changing the board but not the compressor then you have a bad compressor.
If you have one of those units like some whirlpool/Kenmore/Inglis that have electronic controls in the refrigerator section, this is the board that controls the thermostat and compressor on/off cycling. The board behind your freezer is also connected to the board in your fridge, this one controls the defrost.
Sep 27, 2009 | Amana Refrigerators
Fridgidaire 18 cu new defrost timer and evap fan stil freezes
Did you replace the timer with the correct one for your refrigerator? If so you may need to check the defrost thermostat out.
Mar 26, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
120 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
