Question about Electro Brand Nostalgic Stereo CD Music System Shelf System
Tonearm on Memorex 9290
I just purchased a record player, CD burner combo. The tonearm is stiff, when the arm gets to about the fourth song on the album. It won't go over any further and finish the album, it stays there and sounds like it's stuck on a scratch.
SOURCE: is the memorex 9290 recorder a quality unit
memorex record to CDs --- CD will not play on other units
Posted on Apr 22, 2011
My bang and olufsen 7002 wont select the phono stage
The Phono/Aux input has a slider switch to the left of it to choose whether to make it a regular line-in jack or to utilize the phono stage. The ground terminal is just above the jacks. The Beogram 4002 likely has a muting circuit that's in effect when the tonearm is in the lift position, which would explain the lack of hum til the stylus lowered to the record.
May 19, 2015 | Bang and Olufsen Audio Players & Recorders
MAKE MY TONEARM STOP SKATING
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Jan 11, 2008 | Audio Players & Recorders
Technics SL-10 does not rotate
OK a blast from the past. There is a switch that is in the base which senses that the cover is closed and this unlocks the arm and disk motor can rotate. The reason that the disk rotates when the cover is up is because this allows the disk to spin up to speed before the arm comes down. Once the cover comes down the switch unlocks the arm and the arm then moves this switch also can stop the disk if the arm does not unlock.
Sep 11, 2007 | Audio Players & Recorders
How to burn a Cd
The Sony MHC-BX2 can record from a CD to a cassette tape. This model doesn't have a CD burner. The manual for the MHC-BX2 is available from Sony support: http://esupport.sony.com/US/p/model-home.pl?mdl=MHCBX2&template_id=1&region_id=1&tab=manuals#/manualsTab . See page 12 of the PDF.
If your unit is a different model, please post a comment with that model number. I wish that I had better news for you.
(on those shelf systems that can burn a CD, place a blank CD-R or CD-RW (if supported) in the disc tray. Use the function button to set the recording source (Phono with the Croseley units). Place the tape to record in the tape deck and press play reach a point a bit before the desired point to start the recording. (Some also will record from the radio, turntable, or other device. Again start the source playing.) Then press CD Record. Press Stop when you want the recording to stop or when one side of the tape/LP is finished. (Some have a Split Track button if you want to identify every track. Press this during the silent period between songs.) Otherwise, you will get one track per side with tapes/LPs.)
Jul 10, 2012 | Sony Audio Players & Recorders
I have tried to record from Tape to CD with No result. I have followed the instructions for this task, to the letter and still nothing on CD.
First make sure yoou are using correct cds. You need CDR Audio discs not blank pc media type (Yes they are different). Once you have the disc type right, make sure you are finalizing the disc as they will not play in other machines until u do this
Oct 30, 2010 | Electro Brand Nostalgic Stereo CD Music...
Have a Jensen Audio CD-472 portable AM/FM Stereo CD player that won't play my Memorex CD's that I compiled with songs in MP3 format. Can you tell me why this has happened? The commercial CDs I have in my...
I know that some players were not designed to recognise some formats of CD, often those created by computer drives. But if it did play them it must have developed a fault in the electronics part that recognises CD formats. Hence it's problem now. Without a service manual perhaps a tricky thing to put right.
Jan 06, 2010 | Audio Players & Recorders
Record player sounds scratchy and tinny
Playing records is a contact sport.
Since the needle touches the record -- as opposed to a laser reading a CD -- any bit of dust or mold translates to annoying pops and hisses.
Record cleaners get down into the record grooves to extract dust and particles.
Or you may need a new needle.
Mar 25, 2009 | Electro Brand Nostalgic Stereo CD Music...
Is the memorex 9290 recorder a quality unit
Feb 22, 2009 | Electro Brand Nostalgic Stereo CD Music...
Can't finalize cd on the Electron Brand 9290 Nostalgia CD Burner
In stop mode, press "finalize" (last button in the top row of buttons), then press "play" (center button in the lower row of buttons).
Jan 02, 2009 | Electro Brand Nostalgic Stereo CD Music...
Electro Brand Nostalgic Stereo CD Music System Shelf System Logo
211 people viewed this question
Top Electro Brand Audio Players & Recorders Experts
Ben Armstrong
Are you an Electro Brand Audio Player and Recorder Expert? Answer questions, earn points and help others
